Hi guys,
I've recently become the owner of my first Skyline (model in title) and have been perusing this forum before and after my purchase, which has been an absolute help to me and was wondering if anyone could help shed some light on a problem I've been having.
Problem 1: When I put my foot hard down, going into the high RPMs, it feels like the engine struggles a bit, gives a little then goes back up then gives a little then continues on, almost like lagging a bit - anyone familiar with this problem?
Problem 2: I have had an engine light issue "half diagnosed" where the engine light, TCS OFF and SLIP light comes on. Was plugged into a scan tool and all I got back was "Ignition Source Primary" which the mechanic and I both thought that the coils were on the way out. Any help with this one would be good. Seems to disappear when I turn the car back on after some time.
First problem I thought may have been a faulty CAS or slightly out of position or dodgy fuel injectors. The second problem I think the coils, but I'm very beginner when it comes to the mechanics.
Thanks a bunch guys
AFM
Weak spark
Boost leak
Sorry can you be a little more specific on what those are exactly. The car is basically stock, only aftermarket parts are some strut bars
I am partly insinuating that you should google say "afm problem skyline" and see if the symptoms match your description.
And your issue can be taken as miss fire which is caused by a weak spark.
A boost leak would also cause hesitation while driving.
However none of these can be adequately diagnosed over the Internet and will require a lot of research on your behalf.
Faulty CAS would be my guess too, I had a pretty similar experience: http://www.sau.com.au/forums/topic/326043-resolved-misfire-in-r34-gtt-rb25det-neo/
I reckon RB25's actually come with misfire built in, never seen an engine with so many things that could cause a stutter... ;)
  • Like 1
  • 4 weeks later...
...plugged into a scan tool and all I got back was "Ignition Source Primary" which the mechanic and I both thought that the coils were on the way out
And you're 100% correct, this *IS* the problem. The packs will initially fault when warm (continuity in the circuit breaks) when cold continuity is fine. The simplest answer is often the correct one. Every other fault people are listing *WILL* give a different error code, primary ignition = coil packs, no ifs or buts.
Replace all the packs with Splitfires and don't look back!
  • Like 1
As I suspected too, real shame.
I know every man and his dog suggest Splitfires for these but I don't have that much on me outright otherwise I'd love too.
Was looking at these el cheapo ones that come with a one year warranty until I can save some dough for the Splitfires and not have my R34 running on 5 cylinders http://www.ebay.com.au/ulk/itm/221665070389
Anyone know much about these? "Japtek". I know you get what you pay for but its just something to tie my over
Poor man pays twice. They should be ok for stock power levels but do expect a failure. As above comment, your better off just driving easily, gap the plugs down to .6mm and save for oem or split fires.
Couldn't agree more, I'm pretty novice when it comes to these cars, haven't had mine long (took me about 3 hours to change my plugs, fun but time consuming and trial and error), so I wasn't sure if I should find a cheap set to tie me over or if running with coils on the way out is bad for the engine or not. I don't really hoon around so I think I should be okay.
Have u closed the gaps down? That will help
Now that you think about it.... haha
Yeah, I bought the NGK 1.1's that everyone had recommended and gapped them down to 8's.. think gapping them down to 6 is really going to help?
It should. Give it a go. Can't hurt
.......don't buy OEM either, you'll end up with the same problem down the track.
It's true Splitfires aren't cheap, and it hurts to buy something that feels like a complete non-value adding component (like damn tyres) but you seriously never look back and they can take pretty much whatever you throw at them future tune-wise.
The gift that keeps on giving!
OEM are more than capable and have been proven time and time again to handle big power and be more reliable than aftermarket. People usually go split fire because they're cheaper. People have problems with oem because they have 20+ year old units and expect them to make 300+kW. My 20 year old coils are still going, when the time comes I know what I will be replacing them with.
Do splitfires last 20 years?
  • Like 1
I know they last 11 years.....and counting.....
Those familiar with the R34 OEM coilpacks can tell you that they suck. My original R34, the OEM set started playing up in 2004 (5 year old car at the time) I actually replaced them with SII R33 packs which seem to be made of sterner stuff as they worked fine, but they don't fit well at all due to bolt pattern.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
