Hey all,
I have installed my FMIC but unfortunately there was one side-effect I hadn't planned on.
I use the standard air filter box and now a FMIC pipe is blocking its path and the intake from front of bonnet no longer fits.
Now when driving the boost comes on strong at 3500 and hold firm but there is like a soft/flat spot in mid to high revs. in second i seem to only be able to pull 90kms instead of the 100 i used to pull. :P
This soft/flat spot is there in all gears.
I'm hoping that the problem is the air filternow not getting enough cool air.
I was hoping for some clarification on this.
anyway if it is that I will get a pod filter setup w/ partition and make up a feed from the front left bumper as I now have one of the standard intercooler holes free for intake.
Please say this is the problem!!
As i said, it' doesn't seem to be a boost problem. It is boosting to 8 psi and holding firm even through the flat spots.
thanks for any help/opinions
https://www.sau.com.au/forums/topic/46069-intercooler-install-and-problems/
two words...
Standard Computer.
The more mods you do, the more airflow the engine gets, the bigger that flat spot gets.
You can see it on a dyno graph. It's where the AFR plummets from about 12:1 down to 10:1
[ Yeah great, I've got the same problem... put in a FM cooler with 63mm pipes put a free flowing gtr finer air filter in with extra breather pipe into the stock air box, and upgraded the exhaust by putting free flow resonators in and I started getting this flat spot around the same speed. Havent set up my new boost controller yet so its still running stock psi of 6 or 7. What did you fit to fixe the problem??
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
