Up for sale is my r32 gtr ( r32,4 gtr ) needs some love and attention:
the fibre glass wide body kit has stress cracks in some spots. will be sold with space saver wheels. will need to be towed.
car is also runing stock ecu ( it will start,but its rough due to not liking having no afm and running 800cc injectors) for the time being while the vipec ecu gets checked over as car wouldnt start with it. possible damage to the board from hooking up battery wrong way,
engine possibly needs a new head gasket and/or valves cleaned for sitting for a long time. has low compression on 2 of the cylinders due most likely to those reasons.
as for the good bits, Interior is in good condition,shouldn't take much to get it going.
Would suit someone who knows what they're doing or has a budget to get it running and looking good.
will look awesome with some TLC
Also just put in new NGK BCPR7ES spark plugs, new Optima Yellow D51R-T1 battery and a new POD filter.
probably alot of other mods i don't know about
would make an awesome track/drift car
car is full of potential in the right hands. my knowledge of cars was my let down but someone with more knowledge could make this car shine and become a beast of a GTR
Car has 117,502 kms . car has no been driven in a few years
Engine:
RB26
T04R Single Turbo kit
Stainless Manifold,
60mm Tial Wastegate
Tomei 260 Poncams
Tomei adjustable cam gears
Sard 800cc Injectors
Sard 280ltr Fuel Pump.
Gates timing belt.
R33 oil pump
Braided fuel lines.
Management:
Vipec ECU
as well as stock R32 ECU
Suspension:
Tein Mono-flex fully adjustable coilovers
Cusco rear strut brace
Driveline:
Stock 5 speed
Exedy triple plate clutch
Nismo short shifter
Brakes:
R33 GTR Brembos calipers all round.
DBA slotted rotors.
R33 GTR ABS unit.
Wheels:
space saver wheels (lol)
Interior:
Recaro SR reclinable drivers seat.
Jaycar speakers all round
Nismo 260km Cluster
2/4wd Switch.
Turbo timer
Viper Alarm
EXHAUST:
4" Veilside exhaust from Turbo back. With 2 centre mufflers (quiet)
Exterior:
Customised Full genuine Bee-R (B324r) Widebodykit with R34 gtr front end.
R34 Xenon headlights
Sparco alloy fuel cap.
post-14097-0-11352500-1446196425_thumb.jpgpost-14097-0-48395100-1446196541_thumb.jpgpost-14097-0-18371700-1446196551_thumb.jpgpost-14097-0-63155500-1446196560_thumb.jpgpost-14097-0-07759100-1446196592_thumb.jpgpost-14097-0-54672600-1446196601_thumb.jpg
what the car used to look like before previous owner painted Matte Black
$8,000 ONO
Edited by deprived777
https://www.sau.com.au/forums/topic/460690-r324-gtr-victoria/
PRICE DROP: $7,000 dropping price due to realising car will need some money put in it to get it perfect. if someone parted this out they would quite easily make profit. i just don't have the time,knowledge or patience to do it myself. Or invest time and money into it and have an awesome looking car that will turn heads. i've never seen another car like this on the roads personally
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
