Starting to part out a white S2 R33 1997 located in north Brisbane . All that is missing is front and rear seats.
Car has travelled 120000 kms.
Heaps of parts available.
Almost all aftermarket parts have been on car for less than 8000kms and are in top condition
Some parts that may be of interest:
Garrett gtx3071r .82 internally gated with custom dump $1500
Link G4 plug in ecu to suit r33 + 7 bar map sensor $1450
Kakimoto Regu 06 & R cat back exhaust with titanium tip $500
Power Enterprise 850cc injectors $550
Splitfire coilpacks $300
Kaaz 2 way in housing $650
Near new Nismo mats ( set of 5) $200
Greedy Profec B spec 2 electronic boost controller (black) $200
Buddy club rear camber arms $100
Turbosmart plumback BOV $150
I also have the motor (120000kms) , gearbox, jim berry clutch ( done 8000kms ) but I have not got around to removing them yet. Keep you posted!!
Also have a factory Momo/Nissan airbag steering wheel in mint condition (I think they are hard to come by)
Hicas eliminator kit almost brand new ( installed but car has not been driven since installed )
KYB struts and springs all round ( about 20mm lower ). Don't have a price for these, PM me an offer if you're interested in these.
There are way too many parts to list individually. The car was complete apart from the seats and all panels are straight and paint is in great condition.
If you are after parts that aren't listed PM or text/call me and I'll let you know if I have it and a price.
I'm happy to post some items
Will upload pics as soon as I get a chance
Phone: Zero 41044593 Five
Cheers
Edited by ThirteeThree
Hey guys
Update for the ecu. It is a standard Link G4, not the G4+.
Also price drop on the Link G4 with 7 bar map sensor $1300.
Will seperate. Link G4- $1150
Map sensor-$150
Also got some more parts to list:
Tomei 248 L/H fuel pump- $180
R33 GTR brake master cylinder- $100
Brand New HEL braided clutch line- $20
Update. The following parts are sold.
ECU
Turbo
Coil packs
BOV
Boost controller
Exhaust
Clutch cable
Still have:
Power enterprise 850cc injectors $600
Kaaz 2 way diff $600
KYB buzz spec damper adjustable suspension $200
Hicas eliminator kit $150
Just letting everyone know that thirtythree was awesome to deal with, parts are exactly as described and packaged really well as to avoid damage in transit :)
Thanks heaps!
Hey,
Chasing up a few bits and pieces:
- Boot struts ( reasonable condition )
- Driver's side front door lock
- handbreak lever ( just want the grip but it's tough to remove so maybe whole thing ) http://www.sau.com.au/forums/uploads/gallery/album_5832/sml_gallery_1308_5832_102651.jpg
- blend door actuator
- Driver's side seat belt
Cheers,
Pen
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
