hi i currently own an r33 non turbo and i am thinking of upgrading it to the gtst. i just wanted to know if there is much difference in the problems that go wrong with them. the only problem i had with mine is the clutch and now its all fine.'
so would it be better to keep the non turbo or buy a turbo. your opinions will be greatly appreciated.
thanks
https://www.sau.com.au/forums/topic/46075-should-i-buy-a-turbo-or-keep-my-na/
it all comes down to the condition of the car u get. sure there might be a little more things to look out for cause its a turbo but in the end if u maintain it well u'll have no probs. ive had my car for 4 yrs now and the only probs ive had is a sqeaky clutch, worn thrust bearing, worn castor bushes and recently a dead power window motor. all due to wear and tear and all minor issues. i guess when u start boosting without knowing what ur really doin then u can come into some trouble. but yeah...once u go turbo u dont want to go back:D:D
sqeaky clutch
was this due to the slave cylinder? I've heard this is the problem... I'm getting a slight
squeak from mine... like it needs a dose of WD40 or something...
not too sure...
help is appreciated.. cheers
-Eug
not too sure...
-Eug
yeah the sound is definitly commin from the slave cylinder. i have tried to wd40 it but it didnt do much. i also heard that its not a good thing to start sprayin stuff into it. so im not sure.
yep like i said....once u go turbo u dont want to go back:D
