I'm really enjoying driving around in this and especially the near dead silence within the cabin, all except for the exhaust of course which I don't mind.
Any know the flow rate of the OEM fuel pump and it's awkw capacity ?
Really don't want any pump whine if I can do without it.
cheers
https://www.sau.com.au/forums/topic/460757-m35-fuel-pump/
Iv had the dw300 deatschwerks pump in tank and a walbro 255 in tank, The walbro is just a little louder the DW. The DW only lasted 2.5ish years
Isn't it spelt doucheworks? Sorry, I couldn't help myself.
https://www.sau.com.au/forums/topic/460757-m35-fuel-pump/#findComment-7632286
I'm running a RACEWORKS 340LPH E85 Safe pump in the std housing. Small amount of filing to the bottom cradle cap clip holes to lengthen the assembly. OEM wiring with 20A fuse.
*needed direct 12v to initially purge the pump
https://www.sau.com.au/forums/topic/460757-m35-fuel-pump/#findComment-7632353
So they fit in Matt? I saw they were longer and would require cutting compared to the Walbro.
Did you run a direct power feed? I doubt the Raceworks/Proflow/Chinese e85 pumps will like the low voltage on idle/cruise for long.
https://www.sau.com.au/forums/topic/460757-m35-fuel-pump/#findComment-7632388
No they don't fit easily but are do-able.
What I think is a small amount of mods would not be as easy for the average enthusiast, I'm sure you would have no issue's scotty.
They are definitely longer which is why the bottom assembly cap required modifying to enable the assembly to clip together with the pump installed. The original pump rubber bottom cap doesn't fit, I used some less density rubber provided with the pump which takes up less space. The plug is required to be rewired, the bottom keyways and fuel filter captive washer post need shaving. OEM fuel filter is a little loose, now held on by the assembly bottom cap and foam.
It did require a 12v direct feed initially to enable the pump to purge. Haven't had any other issues, flow at idle voltage was ok. I asked about running OEM low voltage prior to purchase and was given a green light as the windings are different in these pumps compared to others...possibly why it is physically longer. I suspect voltage during cranking to be reasonably low anyway...food for thought.
Time will tell if it remains reliable, it's only been in for a couple of weeks.
Comes with a 2 year warranty ;)
https://www.sau.com.au/forums/topic/460757-m35-fuel-pump/#findComment-7632471
  • 3 months later...
Ok, So I've got a Walbro 255 sitting on my shelf still.
Is it still worth installing it if I choose not to tune ?
I'm looking at everyone's dyno results and the peak power it way too late for what I want.
I guess that's part of auto transmission.
https://www.sau.com.au/forums/topic/460757-m35-fuel-pump/#findComment-7688892
Your stock pump is 15 years old, I know I would be changing it... It will require decent wiring, a fuse and relay to install properly, Walbro pumps don't like the low voltage supplied during cruise and idle.
Just remember, peak power in some cases might be almost triple the stock power and 30+psi, most highflows would still outflow a stock turbo by around 3000 revs. Plus when looking at the curve, having the torque converter locked Vs unlocked makes a fair difference. In manual mode it's trying to lock, in drive it is unlocked. All my results are skewed to look laggy, as the converter is locked, where as I drive on the street with the lockup clutch disconnected for better response and gearbox longevity.
https://www.sau.com.au/forums/topic/460757-m35-fuel-pump/#findComment-7689257
Well, other than the MAP sensor boost cut, the rest is based off airflow, so every car will be different. Bump up the boost and see how she runs, shouldn't be too hard to find the sweet spot.
If you are running a highflow, that boost level may be less than stock.
https://www.sau.com.au/forums/topic/460757-m35-fuel-pump/#findComment-7690272
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
