Hey folks,
I have a 2001 V35, with a sunroof. I'm also 198cm tall.
Since the sunroof opens internally, the roof liner is quite a bit lower in the sunroof model than the non sunroof model. I was wondering if anyone knows if it's possible to lower the seat lower than what the electronic controls will do it? (So I'm thinking take the drivers seat out and remove some spacers or something or take it into the local Nissan dealer and see if they can change the seat runners for something else).
Has anyone had this issue before and come up with a solution? I'd only need 1-2cm more room. I fit in it fine after work, just in the morning I'm slightly taller and it makes my head brush against the sunroof surround ;(
https://www.sau.com.au/forums/topic/460770-drivers-seat-height-in-v35/
no spacers to be removed and I doubt a nissan dealer would be interested in doing anything for you, especially being an import.
I think the options would be to have aftermarket seats fitted, or take it to an auto upholsterer and see if the can remove some of the foam padding in the seat base.
Edited by sonicii
If you've got a V36 then you can lower the original seat slightly :) I did this soon after I got mine as I'm ~192cm and have a sunroof. This is the guide I used.
V36 seat height/adjustment mod
Just had a quick search and found this one for the V35. Unfortunately it doesn't seem like you can get quite as much extra adjustment from dong it in the V35.
V35 seat height/adjustment mod - Look for post by GWord256 (#44) on page 3.
Thanks Heaps.
Mine was a little different. I didn't have that thick metal washer. Only had the rubber and the one with the lip. But i replaced the the other thin one that had the lip on it with a flat skinnier one and wound the nut back so it was just on.
Got a little more room for my head so im happy.
Thanks for that Fri_33! I'll have to try that next week :D (out of town for the rest of this week).
I couldn't work out a google term to find anything useful (including 'I don't fit in my V35 Skyline!'), but I recalled reading something about it being possible when I was first looking at getting the car, but hadn't been able to find where.
No probs, hopefully you can get some more room. Us tall guys have to stick together and try to sort out these issues. I ended up with custom rails in the R33 to get as much room as I could after trying a bunch of different seats :)
I forgot to mention mine is a coupe and I assume all the things I posted are for a coupe also. I don't know if sedans differ.
The only thing I would probably like is to get the steering wheel a little closer to me now. I haven't actually looked to see if there is a similar mod that can be done with that. I'm a little more cautious of messing with the steering wheel. Would have for shafts to disconnect or wires strip from it moving too far. I figure it works in a similar way with the steering wheel with the steering shaft having a spline to allow it to go in and out.
Mine is a sedan, but in one of those links was a series of pictures taken looking through an open back door, so it must work for the sedan too. That was something that I did like about my old Toyota Mark II (Chaser, x90), the steering wheel went up/down/back/forward and could pop up out of the way when you got in and out.
I also find it a bit odd that the instrument cluster moves with the steering wheel in the V35.
So, I've done it. In theory it works, but now rather than the seat hitting a stopper, it now hits against the left hand runner and can't go any lower on the left, but the right keeps going down. I've got maybe 1/2 a cm extra, if that.
  On 02/12/2015 at 4:51 PM, Howaitonaito said:
Surely you would have sat in the car and tested everything before you bought it. So it's pretty much your own fault
Really?? Ever imported a car before?? Hard to sit in it when it is in Japan... I didn't realise mine had a sunroof until it got here. Pictures and description didn't reveal it. If it didn't have the sunroof, no problem.
  • Like 1
    • That may not be so tricky with a changeover relay (again, with LED indicator only to reduce load on existing headlight + source)  30 to indicator + globe side 86 and 87 to headlight parker + 87a to original indicator + chassis side 85 to chassis/earth repeat on each corner, sorted, no diode required
    • There might have been some "hard core" decalcification going on in the cells to create that noise As for chargers, I stick all our cars on a trickle charger every few months to "clean out their pipes/cells", the Mrs battery in her Mistsu ASX is still running its OEM from new battery 10 years on, and that thing does alot of short drives, and it can sit around for ages without a good long run
    • I'm not sure the diode only will give the desired result. I'd probably approach it with a couple of relays (And you still might need a diode too!). You need to be able to break the constant feed from the headlight to the orange corner globe when the indicator is flashing. Not knowing which Skyline we're talking about specifically here too (And it may not matter, but I don't know the R34 column switches) you'd likely need to rewire the stalk, so that the indicator power itself no longer runs through the stalk too, as now you need it able to trigger a relay that will break the constant supply from the headlights to the indicator, then you'll need a separate relay to trigger the indicators to come on (Replacing the internal action of the indicator stalk).
    • Weird story from me My Toyota 86 was with Commbank comprehensive but for market value (who they use to underwrite is unknown) When I munted it beyond financially viable repair in 2020, rear end smashed in to the point it bent the rear quarter and roof, they knew I paid $31k cash for it because I told them, they still paid me out $38k, as all the 2017 limited edition variants with typical Km and condition were going for between $36-41k, so they did weird math and came up with $38k I never officially mentioned any of the mods that I had done, but as they were not the cause of the crash they were not fussed at all, the insurance inspector actually asked if I wanted to replace all the mods with the OEM stuff if I still had it laying around before they took the car I still came out of it behind though, because I had probably dropped $20k in it with the suspension (bent after the prang), wheels (bent as well) and "other" mods, that the inspector asked about But still, as the market value was higher than what I initially paid, and they paid out market value To say I was surprised with the outcome would be an understatement  Weird, but true, but probably just lucky with the inspector on the day I guess  Sadly, I don't think if I munted the old NC1 MX5 I would get the same result Meh, pay to play
    • Well, the car is back, all straight and shiny, for how long for is anyone's guess  After picking it up we went for a bit of a drive, Jebus I really enjoy driving this little thing, hopefully the weather let's us go for a nice long cruise this weekend as it will be out of my hands for at least a few days next week when it heads back into Mania on Monday It's weird, whilst I do always enjoy going for a drive, the NC makes me feel like a kid who has just got his first car, and they just want to drive wherever and whenever they can I really need to look into the MX5 Club of NSW
