Just curious as to what peoples thoughts are on pushing a factory RB26 fuel rail with E85 on board to around 450rwkw?
When does the return line being too small become an issue?
For reference i notice the motive dvd R32 runs std rail with a 2nd feed at the back and managed 460+rwkw!
Im trying to keep the engine bay bone stock appearance which is tricky and i refuse to compromise on engine safety so if it needs a aftermarket rail ill get one.
Or ill probably just settle for less power to keep it 100% factory looking.
Cheers
Edited by mr skidz
https://www.sau.com.au/forums/topic/460779-std-rb26-fuel-rail-power-limit/
slightly off topic skidz but just curious what you did on your induction side in order to keep your engine bay looking stock (currently undertaking the same process) and had issue with AFM's mating to standard airbox...
not sure I understand your question.
what's wrong with your air flow metres and mating the factory air box.
Mine will be present but reading from a map sensor
Over 500 awkw at least on petrol - read SK's comments:
http://www.sau.com.au/forums/topic/112475-aftermarket-fuel-rails/
thank you kiwi I'll have a read when I get a chance but the issue really isn't the possible Power outcome on petrol as I know I'll need much less volume of petrol to hit those numbers but now my engine is higher compression and now E85 is being used I require much more volume of fuel.
Cheers Skidz, wasn't very clear sorry but you answered my question anyway.
I need AFM's as I'm running a 'Nistune' ECU, you obviously get round that running a stand alone.
The Z32's I purchased are larger in diameter and therefore don't mate up to the standard airbox.
Now purchasing either Nismo items or refurbished stock items that flow more...
I bought a set of Nismo air flow metres originally but I was concerned with blowing hoses off and being stranded in the middle no where, the map sensor car should still be drivable so this is an advantage for me plus going E85 now so now it's haltech all the way
Stock fuel rail/reg/lines
448kw on caltex eflex, 24psi boost and trapped 140mph few weeks ago !
Been running this setup for 2 years now as is
thnks sir, mad results can't argue with that!!
Only concerns the slight difference being the motive gtr and yours were both tuned e70 which makes me wonder when the factory fuel rail pressure would start to drop using the E85% content which needs the extra volume??
the internal volume of the std 26 rail is more than some of the aftermarket rails. Once dual feed modified they generally flow more than the mechanical limits of the engines they are attached too.
should i bother with the 2nd feed then?
Or just try run it as is?
Im gonna give kudos a buzz tomorrow regarding there Bosch 1250cc ev14's with plugs and adapter should do perfectly
Edited by mr skidz
I think you are to worried. Many folk have gone 400+kW on standard rail
been so busy with work at the moment it's hard to research some of the crucial factors towards the end of this build that's all just making sure
I thought id have 200cc spare.
ill need enough fuel for say 6 to 700 Bhp on E85 at any given time.
Add 30 40% for E85 should be fine
2000cc arent on kudos website offered as kit
Edited by mr skidz
I'll givem a call tomorrow and see if they offer the 2000 in there kit.
Would be better since i wont be leaning on the pump with a reg to get max flow from injectors.
Edited by mr skidz
i wont touch the id2000 copies
sooo many failures... worse still is the seats wear and the injectors change over time.
this is the only injector we use for 2000cc and over http://www.aftermarketindustries.com.au/injectors-c49/siemens-2433cc-injectors-p218/
the real ID700s seem to be excellent as a mid size and the delphi 1400cc which are also unmodified are a much better choice for lower requirents.
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
