Hi All,
I have the brand new kit from Gtr35 to bolt straight up gtr32 & gtr33 for sale. You will need the new brake line to suit.
1. gtr35 Brembos never used, only test fit to ensure that they fit R32. There is a little scratch mark from handling to the testing piece- see picture below. Also the nipple plastic cover broke off which only be dispose piece and not require - see picture.
2. 380mm DBA 2-pieces 5000 series
3. EBC sport formula pads
4. Nissan genuine 4 x pins and 2 x clips. Note 1 pin and 1 clip were opened to test fit only.
5. CNC bracket to suit R32&r33
You will need a minimum 18" rim TED37s or LMGT4 to clear, otherwise 19" rims will be required.
All up I'm looking for $6000 ONO to help me recover my cost.
Prefer to be pickup, that way you can inspect the items. let me know if you want more pictures.
Location - Silverwater (working days) or Liverpool (weekends)
Contact - Dennis (0458 221 468).
https://www.sau.com.au/forums/topic/460801-gtr35-brembos-kits-to-suit-gtr32-33/
Front kit only.
Custom made CNC by an engineering workshop in Wetherill Park which cost $1k.
My mate has the brand new rear callipers to match as well, however he didn't get the adaptor made. The rear adaptor bracket will cost about $600 to make. You can have the rear callipers for $1100 if required.
I did as Chris suggested. Used and R32/R33 Endless calliper adapter kit drilled and tapped, and mounted DBA 5000 380mm rotors front and rear. The braking is incredible. Matches the R34 master cylinder, no changes necessary. This is an essential upgrade for any 400kw+ GTR.
  • 3 weeks later...
  • 2 months later...
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
    • These arrived today! Sadly I'm going to probably be smart and enjoy the car as is over the summer/sunny period and save the ~2 weeks downtime it'd take to swap the heads over and tune later in the year. Maybe. It's going to be pretty damn tempting seeing these bolt on funs just sitting in storage when they're ready to go. There's a non-zero chance I end up @The Bogan'ing it.
    • MZ11 Toyota Soarer in Iwata, Higashi Osaka
