Hi so sorting out the parts I need for my car
R33 GTST
Going to go to Haltech
ATR43SS2
Top Feed Rail with Xspurt 1000cc(short) injectors
Im looking to run the boost control through the Haltech rather than run and EBC.
Ive seen heaps of posts about just getting a MAC Valve and the required part number: 35A-AAA-DDBA-1BA but I can only see ebay listings from America and would prefer to buy localish.
Ive now come across Pneutech.com.au and have looked at their brochure http://www.pneutech.com.au/images/pneutech/products/valves/pdfs/mac_valves_broc_lr.pdfPage 27
but the part number is slightly different: 35A ACA D DBA 1BA. would that still be the right one?
Or do you guys have some different options which would do the job. Links and part numbers would be great
Thanks!
https://www.sau.com.au/forums/topic/460811-mac-valve-boost-control-part-number/
Realistically any air valve will do the job, it's not like they are under high demand, nor do they need to flow high volumes of air. If you are running an internal gate then any 3 port valve should do the job.
Have you had a look on Ebay? There are usually many MAC valves on there cheap, but most are in the US as you say. Most air fitting/supply shops will have them, or can get them in, but you will likely pay twice as much locally, or 4 times as much for rebranded Turbosmart style valves.
yeah i was quoted 112 plus shipping from the one i linked. and haltech ones are 150
might have to look around a bit more
also i received the stuff i ordered, earlier this week... thanks scotty
Several will work.
35A AAA DDBA 1BA =NPT
35A ACA DDBA 1BA = BSP
Should be about $40
Pneutech are the Mac Valve agents so should be the cheapest.
Hmm clearly a few years since I bought mine. They have roughly doubled in price since then. I have one for you if interested - see PM
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....馃ぃ) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
