Selling my RB25DET long motor, has had a good life, always used Royal Purple 10w40 oil. Less than 10,000km on it since rebuild. Has HKS 256/264 cams and exhaust cam gear. Valve springs. Wrinkle red rocker covers. Nismo engine mounts. On 21psi with a 3076R producing 340kw it didnt throw any oil what so ever. zero blowby! After $3500 ono for complete long motor.
Minus ps pump and alternator and starter motor (can be thrown in for extra)
Pickup melbourne/thomastown
Phill 0421 986 981
no receipts for rebuild as i baught this off a friend who burnt around 5k rebuilding it. Then i threw in cams and springs and ex cam gear.
Can ship at buyers expense.
Will be compression testing it soon.
  • 1 month later...
  • 3 weeks later...
Tests came up as follows. Note: this was done dead cold hence fluctuations of numbers.
Cyl 1 130
Cyl 2 140
Cyl 3 150
Cyl 4 160
Cyl 5 160
Cyl 6 155
How much would shipping be?
No harm in throwing an offer is there?
Im borrowing cash to either rebuild or get a new engine so i can keep the car
I just got my full licence 2 months ago and bought my car a month ago.
Working only casual due to back issues, getting a divorce and starting uni this year, give me a break man
Giving somebody your personal story wont alter the price. I'm a hater of lowballers. Regardless of your personal sicho the price is the price.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
