Selling my RB25DET long motor, has had a good life, always used Royal Purple 10w40 oil. Less than 10,000km on it since rebuild. Has HKS 256/264 cams and exhaust cam gear. Valve springs. Wrinkle red rocker covers. Nismo engine mounts. On 21psi with a 3076R producing 340kw it didnt throw any oil what so ever. zero blowby! After $3500 ono for complete long motor.
Minus ps pump and alternator and starter motor (can be thrown in for extra)
Pickup melbourne/thomastown
Phill 0421 986 981
no receipts for rebuild as i baught this off a friend who burnt around 5k rebuilding it. Then i threw in cams and springs and ex cam gear.
Can ship at buyers expense.
Will be compression testing it soon.
  • 1 month later...
  • 3 weeks later...
Tests came up as follows. Note: this was done dead cold hence fluctuations of numbers.
Cyl 1 130
Cyl 2 140
Cyl 3 150
Cyl 4 160
Cyl 5 160
Cyl 6 155
How much would shipping be?
No harm in throwing an offer is there?
Im borrowing cash to either rebuild or get a new engine so i can keep the car
I just got my full licence 2 months ago and bought my car a month ago.
Working only casual due to back issues, getting a divorce and starting uni this year, give me a break man
Giving somebody your personal story wont alter the price. I'm a hater of lowballers. Regardless of your personal sicho the price is the price.
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
