Hi guys just a quick question as I've done a search.
Do I need to bleed the front passenger side brake?
This was my first time having a go at changing the rotors and pads and I undid the bolts that held the caliper in place (starting from bottom to top). I realised that when I undid the last top one slightly some fluid came out so I redid it. Now I'm wondering do I need to bleed just that side? Thanks, I'm new to brakes so be gentle.
https://www.sau.com.au/forums/topic/460832-to-bleed-or-not-to-bleed/
There shouldn't be any fluid coming out when you're removing caliper bolts. You had best show us a photo of what you mean.....because if you were splitting the caliper accidentally, you might be in some trouble.
And here's a pro tip. ALWAYS bleed brakes. Every opportunity.
  • Like 1
Yes the caliper split slightly, but I still had the top one done up. It was only till I loosened it slightly that fluid came out. It's all together and well, I just need to know if I need to bleed that brake specifically.
I will bleed them all when I get the chance, but would I be able to drive it as it sits now?
Off the record, your not supposed to split the calipers, the bolts are torque to yield items and should be replaced, as should the oring that seals the 2 halves.
Having said that, i know heaps of people who have split them and reused the old bolts.....but with a new oring.
Yep, you have to bleed now, no ifs or buts about it.....dont even think about driving it, you don't know how much air got in.
I know I wasn't supposed to split it, but I didn't know those bolts held the caliper together.
So now I've got to get the caliper pulled apart to replace the o ring?
OK bleeding it isn't such a problem now considering I don't know the problems I have made, by slightly loosening the caliper.
Edit: I'd also like to add that it is not leaking at all since I did up those bolts.
Edited by Dan93
So you tested it while hot under full pressure braking with the master full of vacuum while the caliper flexes under high speed load?
You 100% sure it wont leak? :)
Hence why the oring should always be replaced......
    • The answer to this would be I followed the documentation from Turbosmart which said each spring pressure could achieve a maximum of 5x it's rated pressure so the included smallest spring being the 6psi had a range up to 30psi. I went with the 12 because I figured it'd likely hover around 15psi as a base pressure however I was obviously wrong.    I have a log here that I'll dig out that is purely wastegate and no Mac valve controlling anything.   If it can't hold anywhere near 12psi, does that mean the straight gate is virtually wide open during a run? Or am I thinking about this all wrong.   I could Tee Piece into the cooler pipe pre intercooler where the wastegate gets its feed, and send that to the ecu and see how that reads, I just don't have a spare pressure sensor currently that's all.
    • lol nice, I wouldn't worry about sanding back the filler to check for rust then. Yep very much a thing. Personally I don't do the panel beating, its very easy to have a panel beater sort that out for you. If they aren't doing any prep work the actual panel beating generally doesn't take long at all.  Have you taken before pictures before you started this project? I'd be keen to see the before and afters when you're done.
    • Some good discussion in here, for the most part I can't really add too much to it - thought I'd add some notes to the datalog screen shot that probably aren't news to anyone but a good prop... this is assuming 25psi-ish should be the boost ceiling given the first post refers to 23psi.   To state the obvious, this issue seems super weird.  Turbo speed seems pretty lethagic to build, like the turbo isn't getting as much drive as it needs - and it doesn't help that wgdc keeps rising AFTER boost target then completely shuts duty at a point, which in theory should have the straight gate dump heaps past the turbo and funnily enough causes the huge drop off.  It seems like pretty blunt boost control tuning but I'd not call that the primary issue, so much as possibly not helping the situation. I'm curious, what does a pull look like with purely mechanical boost control?  Like purely wastegate?   There are things in this log and story that make it sound like there could be a significant restriction in the intercooler piping or something - but then it's also overshooting boost target which is NOT what you'd expect with a restriction.   I can see where people are coming from with the non-linear wastegate bypass (not that any valves are linear for this kind of thing), but it still doesn't make sense that it can't hold <20psi on a 12psi spring.    Have you, or can you try measuring pressure pre-intercooler?  Be pretty interesting to see what's happening there vs in the intake manifold - sorry if I've repeated old ground, I've kinda skimmed over but I could have missed something.  In terms of comments regarding the wg spring being closer to boost target, I haven't used a straight gate but part of the reason for having close to wg target is about fighting backpressure as well - I might be wrong, but I'd have thought that part of the point of using a butterfly valve like the straight gate does you actually don't have to resist pressure at all, on EITHER side of the gate.   It shouldn't need too much leverage to start opening, the spring being more to do with where it triggers opening as opposed to resisting boost & EMAP, though smarter people can correct me if I'm wrong there.
    • Ah the car is a complete shitbox and not even worth a respray lol, for a professional to do it would probably cost 15k because of all of the dings and stufd but I was keen for a side project. Also solved the problem of being bored haha. But with the rust yeah I can always fix that in the future, not a huge issue for me. I found out yesterday that when a dent is created a high spot is created around it (the crown) and to fix it I either need to tap the edges or just sand over it. Which is what made my filler work a bit confusing originally lol.
    • That's some useful information to have , it would be great if we had more local suppliers .
