Long story short, exhaust manifold stud was stripped out, so pulled turbo and manifold off, install helicoil, re-install manifold and turbo. I also removed the cat.
It usually hits full boost at 4000rpm, but now it has no boost until like 6000rpm and even then it's only a couple pounds at most.
Car is 32 gtr rb26 t04z turbo.
As far as I can tell every bolt and hose clamp I undid I have done back up tight as it was.
Thinking computer issue or waste gate issue???
Turbo spins fine and freely as it should.
https://www.sau.com.au/forums/topic/460866-boost-issue/
Similar thing happened to me 2 weeks ago.
  • Boost suddenly slow. Full boost at 4500 rpm instead of 3600 rpm
  • Manifold stud went missing
  • Turbo spins fine
  • Hardly any shaft play
  • Compressor wheel looks fine
Mine however, made a noise. When the turbo was removed, the turbine wheel was checked - a fin was chipped and another is cracked
Hopefully its not the same issue.
Since yours isnt making a noise (is it?) and also a big jump from 4000 to 6000 then I'd also say its your gate being partially open.
Good luck
Edited by statue
  • Like 1
https://www.sau.com.au/forums/topic/460866-boost-issue/#findComment-7634239
    • Welcome back, glad to hear life's wheel is turning in the right direction
    • Awesome pics Rezz, thanks for sharing them Another stop for my "need to do in Japan" list
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
