Hi all,
New to SAU, but somehow I signed up for here in 08. Was probably looking for a stagea at that time.
Recently I've inherited a v35 Premium with the 3/3.5lt v6. This place is loaded with info so thank you very much!
Gotta wait a few more years to get a mates r33 on club plates, but will drag him out for the all Datsun day in Yarra Glen.
If anyone has a good contact for body parts that would be awesome, currently need a front passenger side guard due to a dent, and maybe a bumper for the right price.
Currently dealing with a miss/knock/fuel issue (car sat for well over a year) hopefully I'll change the oil, filters, clean the pick ups and clear the codes. Should all be peaches then.
Must read v35 threads?
Things to avoid like the plague?
Even links to threads will suffice. And after 50+ pages of bickering and bullshit, I'm still none the wiser as to who can convert the screen to English. Just a username will suffice.
Cheers and Beers,
Mark
https://www.sau.com.au/forums/topic/460930-holy-datsuns-batman/
    • Mainly being afraid of breaking something on something i've poured so much money into haha
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
