Lads i have a few bits and pieces i need to get rid off
Im putting everything pretty cheap coz i need the room so please no silly offers
All parts are for a R34
Boot $100
Tail lights oem $100
Rear bar oem $50
Rear bar reverse lights mickey condition $50
Steering wheel oem with airbag $100
Complete dash with glove box $100
Odometer cluster (manual) with 80k kms $100
Complete aircon and factory radio centre dash $50
Abs module $50
Ignition barrell with key and door locks $100
Doors both sides complete minus door cards and mirrors $200
Electric Mirrors both sides $100
Nismo side mount air scoop $50
Rear windscreen wiper motor $50
Full loom for rb25 det neo $100
Full 3" exhaust $350
I might have other things laying around
If you want a pic of any item just shoot me a text on 0433696875
https://www.sau.com.au/forums/topic/460938-r34-parts/
Hi mate, I will buy the ignition barrell and keys and door locks and would u have the bonnet latch/catch as I will buy that too. I will pm u later today. Cheers
https://www.sau.com.au/forums/topic/460938-r34-parts/#findComment-7636209
  • 1 month later...
  • 3 weeks later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
