Hey guys,
Looking at upgrading the exhaust on my R34 GTT over the next few months. I was just wondering what my best options are for with:
- Quiet on idle
- Loud on high RPM
- Offers the highest performance
- Budget of $1,000
Anyone have recommendations and stores to buy from?
Thanks
https://www.sau.com.au/forums/topic/460950-r34-gtt-exhaust-options/
For highest performance you'll want a full turbo back including dump, front pipe and a high flow cat.
I'd offer a couple of other requirements to add to the list if I may:
  • Properly fitted and tucked in for maximum ground clearance, there's nothing worse than scraping your car or mid muffler on speed humps all the time
  • Not droney at standard road speeds 60, 80, 100, 110
The cheapest may not be the best. I have a full frankenexhaust mixed from random parts, it fits well and performs great but is droney and probably ended up being more costly this way too...
Hey guys,
- Quiet on idle
- Loud on high RPM
- Budget of $1,000
This doesn't really exist with the budget you have.
Unless you want to buy like, someone's second hand exhaust and then do a little modding/fabbing to make it fit and work with your setup as every setup is a bit different.
In other words, buy my old exhausts, thanks - Nothing off a shelf is going to satisfy the criteria you've listed
$1000 will only get you something second hand if you require turbo back and it will either be loud or restrictive.
I'd probably try to find something second hand that flows really well and stick a decent muffler in it.
I can probably compromise on a few areas for now. With just a basic exhaust surely $1,000 is sufficient? (Excluding installation)
It can be done, try Jesse Streeter or Import Monster and see if they can supply a Fujitsubo Legalis or similar. Understand these will have a restrictor inbuilt and will struggle to make top end power, but will sound great and be legal or close to legal dB.
Otherwise there are quite a few places that could do a custom stainless system for that coin.
Buy a cheap mig, a hooker aeroflow, a Berkelee straight through.. Some pipe and bends.
Make. It.
Then you also own a shit mig welder. But it's an exhaust. So shit welds are ok.
That's what you get when you pay an "expert " to make one.
You will either crash car or sell it before exhaust wears out......or falls off, depending how shit you weld.
Google. How to weld.
  • Like 2
If you want to get some ideas for a modded setup here's what I have:
  • JJR 3" bellmouth dump/front – customised (to ensure good fit with my Hypergear IWG, and for ground clearance)
  • Venom 3" high flow metal cat – flows much more than the XForce I had first
  • Custom 3" piping between cat and mid muffler
  • Small mid muffler – for good ground clearance
  • HKS Super Drager 3.5" to 5" rear section and muffler
It would have been cheaper to build a full custom system rather than mixing and matching parts over time but oh well. Also full second hand systems for the sedan are like hen's teeth.
And get raped hard. What a bloody stupid idea to promote...
A decent exhaust doesn't improve in power when you drop it.
LoL one out of a million effective methods.
My R34's pumping 380rwkws internally gated with exhaust dropped, make no where where near it with 3 inches exhaust back on. I'm sure you will come up with a quite alternative.
I have a full turbo back system to suit an R34 sedan that I may be willing to part with if anyone ever requires one.
Psssh, I have two of them! :P
How does that system actually work? Because looking at it, I actually thought it was a better (i.e, far easier to hide) system than Scotty's "external gate on housing" setup.
Then again, why not just simply make the dump diameter that size?
Car is currently running a full 3 inches SS Havoc fabrications turbo back exhaust with two megnaflow mufflers keeping it quite.
The idea is getting back pressure out of the exhaust system. Valve is spring pensioned that is forced open by exhaust gas pressure when > 3psi. It is currently opening at WOT in 3rd and 4th.
    • Noice Once exhaust leak is sorted post vids for audible sexy time The thing should be a laugh riot to drive
    • Nah, apparently the way to do it is just mess with how much timing the engine uses to try to correct idle. So it massively undershoots, then overshoots, then undershoots, then overshoots. So timing is going from 5deg to 45deg to 5 deg to 45deg. But I kinda prefer the car to not lurch around and have a dependable idle. Given it didn't idle for shit and stalled about 7 times on the way home, still yet to drive it for the 2nd time to see if it's fixed.
    • Best chop idle FTW, just add an idle timing hole lol
    • Alright. Many little things have been sorted and the car successfully drove home with an incredibly huge exhaust leak. Unsure if it's simply been awhile, but new heads and cam and intake sound f**kin awesome. It might only be me that notices it though, and it's hard to tell from a 15 minute gauntlet run home and attempting to bleed the radiator. Undertrays on, tools out, road brake pads in, idle un-f***ed, time to do some road tuning. From my commute around town it sounds and drives *really* nice (with a max of like 35% throttle). It'll go to a dyno for a proper before and after once the tune is more roughly dialled in. And @Dose Pipe Sutututu I did learn how to do a proper chop tune at idle. I did indeed even do it, but the car shaking around at idle from the driverr seat made me make it smooth again.. I feared for my engine mounts and clerances to engine bay jank. . After the exhaust is fixed I may mess around with it more. I'm just happy to have it drive around without bucking or stalling which is a WIP.
    • Oh and my rear arms may need some attention too.
