Hey all up for sale is a set of 5 used Michelin slicks that I purchased to use on my R34 GTT
Unfortunately the width is just a tad too wide to fit under the front of my car thus I will be selling them off, they are in good condition with minimal or no cracking along the sidewall to contact surface edge and are still plenty soft. Wheels have been mounted but previously they were wrapped in the garage on a pallet for about 6 months.
I currently have them mounted to a set of 18x10+30 Rota Grid wheels for Track Duties (i have a 15mm spacer running on the front making them a +15) if anyone would like to test fit the wheels before I strip them off the rims for sale, Alternatively if you want the wheels as well we can add 1k to the price.
as stated in the title they are a 57D (soft compound) in a 30-65-18 which equates to a 290-295 tread width. The car these originally came off was a r32 GTR with rolled rears and removed plastic guard liners but will fit a 33/34 GTR without any modifications.
Sale Price is $350 plus postage anywhere in Aus.
If you are interested in the wheels they are mounted on (brand new wheels) I will let them all go for $1300 plus shipping.
pics
Located in Penrith NSW (Western Sydney)
Contact Via PM
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
