OK i know that this topic has already been ask but im just gonna ask anyways
so does anyone know or have any updates for the satnav/English conversion ?
and also anyone one knows anything about converting the TV to Au ??
much appreciated
https://www.sau.com.au/forums/topic/460985-v36-sat-nav-and-tv/
Japan uses analogue TV signals which are not used in Australia anymore. We use DVT-B signal so you would need to install a Digital TV Tuner into your car via Video put on console.
i believe this is from what Chris Rogers has said previously: "There are no maps for this unit used in the Australian market. You can install a aftermarket navigation unit to the factory radio via Video input however the touch screen feature wont work (as of now)"
Someone also mentioned to me the format the maps are loaded into the cars are NTSC/PAL (one or the other) and australian maps are only the other kind.
one of the stickied threads goes through this and much more. use google to search SAU.
http://www.sau.com.au/forums/topic/421465-v36-nav-and-language-swap-faq/
I guess doing a little homework here on this site is a very rude expectation.
Updates (as in English conversions) - information is here (second from the top of the thread list): http://www.sau.com.au/forums/topic/421465-v36-nav-and-language-swap-faq/
and if you used the search box in the top right corner just using the letters "TV", here: http://www.sau.com.au/forums/topic/436316-japanese-to-english-conversion-for-v36-oem-swap/
In short, language conversion is difficult and expensive. TV conversion is not feasible, better to consider an external unit plugged into the car's AV sockets in the centre console.
For the rest, do some searching and reading like the rest of us. It's not as difficult as the conversions. ;)
  • Like 1
More accurately, Japan decommissioned analogue in March 2012, so any vehicle manufactured up until then (if not slightly earlier), would have an analogue tuner.
Thereafter, I'd expect them to have DVB-T receivers but nevertheless, the colour system that Japan uses is completely different to Australia (NTSC vs PAL) so even if it did receive our channels, there's the possibility that the receiver doesn't function as a multistandard unit anyway. It's not an expensive exercise to make it multisystem but we're talking about motor vehicle manufacturers here. :/
Nonetheless, your recommendation is the best one but I don't watch any FTA TV at home, so I'm happy just screen mirroring from my mobile phone instead for the GPS or the occasional live webstream.
ok now you mention screen mirroring
what phone do you use ?
is its a iphone it had to be jail broken ?
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
