As topic states I have a genuine Garrett gtx3071r kit for sale, it has everything needed to fit an rb25.
It has only been on the car for just over 6000kms and is in great condition with no shaft play. I have no use for it now as car is no longer on the road. Originally purchased from MTQ in Wetherill Park.
Kit includes:
Garrett gtx3071r
Genuine Garrett 5 bolt 0.82 AR rear housing with internal waste gate
Garrett 14psi waste gate actuator
Spacer plate to fit to OEM exhaust manifold
All braided water and oil lines
All required bolts, washers, gaskets and hose clamps
Silicon joiner for compressor outlet
Custom inlet pipe with K&N pod filter
Custom dump pipe to suit turbo
Price: $1250 ono for kit
$1100 for turbo only
I'm located in North Brisbane. Pickup is fine and any inspection is welcome.
Can also post at buyers cost.
You can contact me on 0410445935 or PM
Edited by ThirteeThree
Hey mate, turbo was making 288rwkw@20psi on 98 and 335rwkw@25psi on E85.
Only other supporting mods were:
Link ECU
850cc injectors
3" exhaust
Front mount
Hey mate,
Cheapest quote I can find is with couriers please. Postage cost to send everything is around $45.
Extra cover for the lot is an extra $20 if you would like that.
Cheers
  • 3 weeks later...
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
