As topic states I have a genuine Garrett gtx3071r kit for sale, it has everything needed to fit an rb25.
It has only been on the car for just over 6000kms and is in great condition with no shaft play. I have no use for it now as car is no longer on the road. Originally purchased from MTQ in Wetherill Park.
Kit includes:
Garrett gtx3071r
Genuine Garrett 5 bolt 0.82 AR rear housing with internal waste gate
Garrett 14psi waste gate actuator
Spacer plate to fit to OEM exhaust manifold
All braided water and oil lines
All required bolts, washers, gaskets and hose clamps
Silicon joiner for compressor outlet
Custom inlet pipe with K&N pod filter
Custom dump pipe to suit turbo
Price: $1250 ono for kit
$1100 for turbo only
I'm located in North Brisbane. Pickup is fine and any inspection is welcome.
Can also post at buyers cost.
You can contact me on 0410445935 or PM
Edited by ThirteeThree
Hey mate, turbo was making 288rwkw@20psi on 98 and 335rwkw@25psi on E85.
Only other supporting mods were:
Link ECU
850cc injectors
3" exhaust
Front mount
Hey mate,
Cheapest quote I can find is with couriers please. Postage cost to send everything is around $45.
Extra cover for the lot is an extra $20 if you would like that.
Cheers
  • 3 weeks later...
    • For the record, I hate the colour. Even if I'll never see it again, I know its in there.
    • This is another issue I'm fixing. This little valve stops all the oil from draining to the sump when the engine is turned off. What happens eventually is that the engine is a little noisy and has the oil pressure light on for a few seconds after turning it on. Basically it takes a few seconds to build the pressure when all the oil has drained. This valve is a non serviceable part and is attached to the oil filter housing, BMW suggests to replace the entire housing if this valve fails.  As it turns out this valve can be removed and that means you can get an aftermarket replacement, which I did. The failure, for me at least is that the valve doesn't seat properly after a while, which I've demonstrated. The new one is a ball end and always seats properly.
    • Welp don't know if this is good but I can hear a sizzling sound in my battery Hope I didn't fry it. Turns out a bad battery in the multi meter will give a false reading (likely what happened when I said I had 15x volts), swapped the battery and monitoring now. I'm hoping that sizzling sound is just the equlisation charging
    • Yeah I'm happy to talk to whoever, I don't want to take ownership or even manage it if they don't want but I can probably help with hosting on the sau setup. It's a great resource and should be protected.
    • So, got some bits..   New oil filter housing gasket (main problem I'm trying to fix -see leak above)  While you're in there's: New belts, pulley and tensioners.  Vanos oil line New oil drain valve New water pump and pulley  New fumoto valve (all my cars have these). Some of this stuff seems ok now that I've pulled it out but I still have no idea how old it all is.  The belts looked fine and then I noticed this. Like somebody has hooked it with a pick.
