1997 S2 R33 GTST in QM1 white
Manual
15XXXX KMs
$5000 firm
Selling due to very limited use. I have put on no more than 20k KMs in the 4 years since ownership. Has been out of rego since Sept 21 but comes with pink slip.
Has not been driven the past few months but regularly gets kicked over for a few laps up the street
Mods:
Blitz return flow FMIC
Fenix auto alloy radiator/silicon hoses
Nismo thermostat
Blitz ZZ-R coilovers (c spanners included)
Daiken HD clutch
Front and rear strut brace
Splitfire coilpacks/NGK iridium
Genuine Apexi Pod kit (Stock airbox and spare AFM also)
HKS Priest 3" cat back
17x9 +22 enkei RP01 in White
Apexi SAFC2
New battery
Alarm with built in turbo timer
Also comes with the below parts but not installed:
Viva garage front lip
3" bellmouth 1 piece dump
3" Hi-flow cat
Stock intercooler/piping
Stock airbox
Spare Pink Label AFM
HICAS lock bar
Due to my move few years back I regret to inform that can not find any documentation/receipts that I have for the car. Searched high and low and hoping they will eventually turn up.
I bought the car absolutely stock with 13XXXXKMs on it. I will try to find the ad that was originally posted up on here.
There are no known issues with the car and has never been in an accident to my knowledge. I have also replaced all manifold studs plus the manifold and turbo gasket due to previous leak. Does not leak and oil/fluids and doesn't blow any smoke. Though the air con needs a re-gas.
If you say you are going to come and take a look, please be professional about and at least let me know if you are not able to make it as I have had to take off work early, deny other people access, just to meet 'seriously interested' people that don't end up coming and not replying to text.
Contact:
Felix
0401905915
https://www.sau.com.au/forums/topic/461008-1997-s2-r33-gtst-5000/
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
