Entry online via CAMS.
https://www.meecamsau.com/index.php?option=com_content&view=article&id=16&eventId=970&Itemid=516
You don't need to have a CAMS license to use the sign-on system. Sign-up, it's free, when asked for a license or club number enter TBA.
Garage bookings can be made through 0403 189 352
Event Partners
Shockworks
Shockworks offers a range of high quality performance chassis components including, 10 stage adjustable monotube shockabsorbers, high performance brake packages, links and rims. We also offer fully customized tuning service and support for road and race cars. Shockworks and NTS have developed a technical partnership that combines, leading tuning and development knowledge with the outstanding engineering and manufacturing quality Korea is now famous for.
SubRegs
Saturday Jan 30th 2016
$205 for members
$225 for others
Come & Try License available on the day for $25
Club day license available on the day or $5
Bacon and egg rolls for breakfast
Hamburgers for lunch
Timed groups available
Non-timed social sessions with passenger laps available
Caped groups for other car clubs
Track walk in the morning with instruction available
Will be a great mix of experienced drivers searching for better lap times, social drivers just out to have fun and novices wanting to set lap times.
We'll be conducting our popular track induction in the morning. Where we will be piling a few of you into cars and showing your around.
Entries
Alex Barnes
Peter Blythe
Rebecca Bottomley
Michael Brne
Brody Carlesso
Mitchell Carlesso
Andrew Collins
James Columbine
Bill Dalianis
Matthew Doyle
Graeme Hadow
Simon Henman
Wai Ho
Vahagn Khachatryan
Carolyn Kruger
Sze (joshua) Lim
Vince Lopizzo
Leslie Maslaris
Jason Mcdonald
Josh Miller
Ken Ming
Timothy Munyard
Peter Owen
Mark Pether
Alan Pettett
Cameron Rees
John Richardson
Andrew Richmond
Paul Stephenson
Alexander Vandenbossche
Daniel Vetter
Terry Vitanopoulos
John Winterburn
JASON CAREY
Chris Madden
Alan Pettett
Michael Brne
Aaron Barnes
carlo urpis
Raff ferrara
Adrian taranto
Adrian Garvey
  • Like 3
Very keen.
With the pricing, what's it all up for a non-SAU/non-CAMS member?
Also re timers, are phone apps allowed?
CAMS for the day is $25 and SAU Membership for the day is $5. So add $30 to the non-member price.
Phone apps are fine and regularly used. Day license holders and passenger sessions are not 'officially' timed on natsoft, as the permit states 'non-competitive' that's all.
  • Like 1
Have an app called TrackAddict that I found worked very well at PI - was .02-.06 seconds off the natsoft times and that's through internal GPS (you can bluetooth to external)...enough variance for amateurs not to worry about :)
Thanks guys that's great! I've used Harry's LapTimer at Sandown and it seems to work very well for the price.
Ive also used track addict at sandown, PI and winton. Was accurate to 0.05 sec and can be used as a camera. Was a little bit patchy at winton on the phones internal gps. Awesome considering it's free. Also used race chrono but moved to track addict for the camera capability. Would love to come to Sandown, trying to convince the wife after writing off my last car at a track day. My new ride needs a shakedown, I have a lot of convincing to do :ermm:. will let u guys know how I go with that.
  • Like 1
Cheers good to know about Winton. Harry LapTimer's recommends Dual XGPS 160 (Sky Pro) as an external GPS sensor/booster: http://www.gps-laptimer.de/compatibility/ios-not sure if that would work with Track Addict.
Track writeoff sounds scary, hope you're ok!
^yeah, I was fine, that was back in june. Car (s15) was parted and now I got me a skyline. I think there is also an external GPS that can be bought for track addict through the app developer but I like free stuff :D
TrackAddict will work fine with most external GPS including the XGPS series - it's the phone and bluetooth compatability that is the question. but yeah, if you're only wanting laptimes, all you're gonna care about is that it logs the start and finish coordinates...in which case internal is fine for accuracy stated above. It just may not give you great looking race lines layed over a circuit (I found it did quite well at PI).
Android - Race Chrono Pro (pay for the app, it's worth it for added inputs etc).
Apple - Harry's Lap Timer
To get decent timing you will need to use external GPS that is suited (google to work it out). Internal phone GPS gets very whack at times and can be a second out. External GPS unit is like $70-$100 and will last all day on a full charge (most are USB).
Then you can upload all that data to Seriousracing.com and full data compare with others ;)
Definitely the way to go for self timing/data logging on a budget and the above set-up/apps is what most of us SAU track guys run.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
