Ok a bit off topic but might be relevant to the January track day too ... I'm heading to Sandown this coming Sunday and the current forecast is 35, ouch.
Any specific prep I should look at doing for such a hot day? I've got Defis for oil and water temps so will be watching those closely.
Does anyone know how R888's go in the hot (standard GG compound)?
Also would i be able to wear a dirtbike helmet for this? or will i need another type of helmet
If I were you I would get a different type, scrutineers can be a little strange with them.
Check your brakes are in good condition and you've got good brake fluid too.
Do the licenses you can buy on the day allow you to enter the Timed sessions or just the non-timed? Just asking as the come and try licences in the Supp Regs are a different level to the normal Level 2S ones we have...
DRIVER ELIGIBILITY
All drivers must hold a current CAMS Level 2S licence or higher and be a financial member of a Club affiliated with CAMS in Victoria.
Come and Try Level 1 Licences will be available to eligible participants, see CAMS website for further information
DRIVER ELIGIBILITY
It's at the discretion of the Clerk. However we will be grouping Level 1 license holders in the social group(s) with no timing.
It will be a discussion if a level 1 license holder would like to go up into a timed group.
Good question Brett,
I will check and get someone to reply.
Thanks Collins / Richo,
Was thinking they would be separated at the start of the day so I can let people know and that there may be a possibility of getting into the timed groups at the discretion of the clerk...
Badically, if head screwed on. They'll have a chance of getting into the timed groups.
If you don't have an oil cooler, you're gonna have a very bad time. Once you see oil temp hit 120 back off as it's gonna climb top 130-135 before it starts to come back down.
R888 will be fine, you'll run outta oil (and/or brakes depending on setup) before the tyres will give out
  • Like 2
And EVO is booked into Import Monster's new service factory with a loooong ass list of shit to do.
I should be a starter for Jan 30 now, need to lock in a tune somewhere in Jan however.
Cheers. I was trying to get the cooler sorted this week but ran out of time, aiming for early Jan hopefully. Fingers crossed I don't cook it on Sunday.
i like that plan as you would definitely want them to know what they are doing before putting them on the track with the guys trying to cut good lap times... :D
Then prepare your ears for tyre squeal and bulk understeer, or has it still got the oem suspension package?
    • Mind if I ask what brand was that alternator? Not to take a stab at the brand, but just curious, as I had voltage drop issues too, but seemed to have stabalised after i changed battery.
    • That shoots down the suggestion they are a similar price to a 5yr older Q50 RS.  if you pay that price for a 2016 RS you would have rocks in your head.
    • It can't be some stupidly proprietary video signal coming out of it that only Nissan's can understand. Surely you can just find some generic camera to stuff in there and use hot melt glue/blu-tac/gaffer tape to hold it in place if need be?
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
