Shameless plug warning!
If anyone burned through the last of their tyres at Sandown, give a thought to this pair of 265/35/R18 AD08Rs I'm selling...
http://www.sau.com.au/forums/topic/462561-fs-ad08r-26535r18-x-2/
I had an awesome time with some decent track time for once and I knocked my PB down to 1:24.7.
Also I noticed in the sup regs that there were awards for different categories on the day? Were these decided as I wasn't there right until the end...
Yep it was a pretty good day and well organised. Weather was also great. Thanks to all the organisers and volunteers who put the hours and effort in to make days like this possible. You guys are awesome and much appreciated.
How'd that oil leak end up?
It ended up not being from the oil cooler setup. Was from the only proper braided Teflon speed flow fitted hose on the car. Turbo oil feed. User installation error, too close too turbo flange. Cooked it and made a pin hole in it. Rob sabbaddin happened to be around and fixed it up for me, shortened the hose and got me back out for another session. I again installed it the same way and it failed again. You live and you learn I suppose. I live just down the road from sandown and made sure the oil was topped up and cruised it home. Fixed it properly the following day. Now I just have gear box issues to worry about lol.
Ah ok. Bummer. But good it was fixed close to home.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
