Then prepare your ears for tyre squeal and bulk understeer, or has it still got the oem suspension package?
I have $3,500 worth of custom valved Tein's (done by MCA) in there :D
(wanna buy my old Jap KTS damper adj gear i took out? lol).
Gonna put the RE003s through their paces if I can. Only issue is I do not have oil temp gauge, has oil cooler - so gonna have to stick to 2 fliers just to be safe.
Sounds like a fun day.
What if we wanted to come along but not actually go on the track, is there still a $225 fee? (read through but I couldn't find an answer).
Wanted to come along to the event and meet some people in the SAU VIC and get their thoughts on gtrs :)
If you don't have an oil cooler, you're gonna have a very bad time. Once you see oil temp hit 120 back off as it's gonna climb top 130-135 before it starts to come back down.
R888 will be fine, you'll run outta oil (and/or brakes depending on setup) before the tyres will give out
^^^ This.
Guys get your oil coolers sorted before Jan 30th, good chance it's gonna be hot. I had to do two cool down laps after pretty much every proper lap today to keep oil temps in check. Brakes were good (DBA T3 + Remsa pads + Dixcel 273C fluid) and the tyres (fresh R888R's) were great btw.
IMO track = oil cooler by default mate.
For $800 or so, it's cheap insurance and will let you run without any issues (and to the limit of tyres/brakes) all day long.
Any recommendations on what to get? Would prefer something RB25DET Neo plug and play with a sandwich plate (with oil temp/pressure sensor spots) and good quality fittings.
What are the details in terms of times? What time do drivers have to be there and when does the track close?
The venue open at 7 and closes at 6. Track action should start around 9.
I've run a justjap kit for years. No doubt a $1000 kit might perform better, but for $350 the justjap kit works well.
If you do get the justjap kit, Teflon tape all the fittings.
  • Like 2
Listen to this man 1st timers or this may happen
Sandown 11th Aug 2012 (5)
...don't ask how I know.
  • Like 1
How many cars will be on track for the timed session?
We're expecting 3-4 groups of timed cars. Groups are anywhere from 10-16 cars. It all depends on numbers on the day.
For the social event, when is the latest we need to sign up by? Is there a limit?
The Thursday before the track day is best. We'll end up doing entries on the day if we don't get the 80 cars max. But entries on the day slow sign-in, which slows the whole day a little.
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
