Whereas my Silva went years of serious track abuse with stock rad and no oil cooler - did eventually do a head gasket though :-)
When i did put in an oil cooler, i wanted it in line rather than in front of a tyre, so water temps actually went up.
Personally ĺ'm all for newbies to not worry, get the fire extinguisher and get out there. You tend to drive like a fairy to start with so nothing too strenuous on the car. Just careful as it goes type of thing.
  • Like 2
JP "The fairy of the track"
Took me one track day to do the head gasket as a newbie.
However...
This was an unopened engine with 270rwkw that has been driven hard every day for the last 6-7 years including a lot of mountain runs. And on a high speed track like PI where I didn't take it easy, I can see why it went.
But I'll be back with a metal gasket and a couple of coolers :)
  • Like 1
Good clarification, concur when you mod a car you need to look at associated/supporting mods - never ending spiral.
Just want people who are thinking of starting out, serviced car with extinguisher is pretty much all they need to attend a "come and try" type event.
If they enjoy it, start pushing themselves, more track oriented tyres/pads/fluids... suspension.... braking/power/cooling etc etc.
Richo, unfortunately the fully covered clothing regulation is preventing me running in my pink tutu
  • Like 1
Yeah, took me a good 2-3 track days before I was driving it hard enough to begin to find the stock limits of the car (brakes and temperatures)
Took me about the same. On my 4th or 5th track day I found a new limit called a tyre barrier. Didn't end well for the car lol :O
And if it was a WRX, it would still be sitting in the garage on stands getting another new engine installed...
And if it was a self built kit clubman , its electrics would get the shits on rough track at Winton.
Hi black :-)
Actually i hear they are puting down new surface
So I don't have an oil cooler (yet) and was going to sit this one out (wuss) but then I receive this tantalising email saying that "Whether you have a hardcore track car, or a clean road car this is the perfect event for you".....
Yeah so my car falls into the cleanish road car category and I fall into the category of not having been near a track for 15 years and even then it was happy laps. Is this the perfect event for me or am I better off waiting for another?
Cheers
Rob
Oh and if you aren't aware water is the more efficient cooling substance - so if you are concerned about engine temps not oil break down temperature issues then it's the water coolant circuit you should look at.
Cheers
Rob
This is the perfect event for you.
Most other CAMS related days don't have the level of introduction and 'social' aspect, at the moment. A few of the clubs are starting to introduce more, this day is full on social all day (and a little more serious for those who are into that).
If you have a standard radiator and no oil cooler, you can still come along. You just have to take that into account. Don't run the whole session at full speed, do a couple of laps then back right off. We'll couch you on the day.
Everyone started somewhere, my start was in a very street driven car. You find out pretty quick the limit of the standard equipment.
  • Like 1
In all seriousness, if any new drivers want to get out and have an introduction to club sprint days - this is your event. Likewise, if you have the opportunity for an experienced driver like John to ride along giving you tips from the passenger seat, I would definitely recommend it! It's always better to start off learning the right way, rather than try to undo the habits of doing it wrong.
  • Like 2
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
