I have the following for sale. All prices in USD. Offers OK. Please check my eBay feedback:
1. Nismo LMGT2 17 inch (fitment for HCR32 and HNR32 ONLY) complete set of four (no tyres) $800
2. Nismo LMGT2 17 inch (fitment for S13) set of two (with tyres) $300
3. Genuine Apexi Auto Timer (bought from Apexi USA) NIB $40
4. Apexi Active Tail Silencer 115mm NIB $100
5. Kakimoto Inner Silencer RIS001 NIB $50 (for Regu 06&R and previous Regu models)
6. R34 GTT SMIC (used, good condition) direct bolt on for R33 or can be fitted to R32 with mods. 50 each, I have two
7. RB20DET Nissan Turbo. Used, good condition. Please use it for building a high-flow, or for maintenance and re-install. It was working fine when removed. $75
8. HKS Glove Box Meter Panel for R32 $100
9. Works Bell Steering Boss for R32 Zenki (with hicas) NIB $50
Edited by Matvei27
https://www.sau.com.au/forums/topic/461024-parts-clear-out-from-usa/
The NIB items are unopened and I am going to leave them that way. As for the used items, let's get some pics up starting with these:
Here's the LMGT2s for HCR32 and HNR32. I bought them at Upgarage. All center caps are included and the wheels are ready to use as is. They have some gutter rash etc. since they are used but if you want you can get them refinished. Tires were removed for shipping and are not included. I can arrange to have these shipped anywhere worldwide. Very rare fitment: Front 7J×17+29 Rear 8J×17+38 114.3-5H
Edited by Matvei27
PS I will accept the following items for trade +/- cash. Maybe you can get some wheels for free or even get paid to take them. Who knows.
1. Nismo Pedals for R32 MT (with screws)
2. HKS GT2530kai turbine for RB25/RB20 (not the vanilla 2530, I have that)
3. Any cool box related parts (R32)
4. Any other R32 factory option parts I don't have or have but want extras of
5. This older style Nismo registration paper case
hashibamusic-img450x600-1428202624eo3kd0
Works bell steering boss is sold. Price drops for other items as follows. Prices in USD
1. Nismo LMGT2 17 inch (fitment for HCR32 and HNR32 ONLY) complete set of four (no tyres) $750
2. Nismo LMGT2 17 inch (fitment for S13) set of two (with tyres) $250
3. Genuine Apexi Auto Timer (bought from Apexi USA) NIB $30
4. Apexi Active Tail Silencer 115mm NIB $75
5. Kakimoto Inner Silencer RIS001 NIB $35 (for Regu 06&R and previous Regu models)
6. R34 GTT SMIC (used, good condition) direct bolt on for R33 or can be fitted to R32 with mods. 35 each, I have two
7. RB20DET Nissan Turbo. Used, good condition. Please use it for building a high-flow, or for maintenance and re-install. It was working fine when removed. $50
8. HKS Glove Box Meter Panel for R32 $75
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
