Hi Everyone,
We have had to reschedule our dyno weekend as the extraction fan for the dyno room was delay due to manufacturing times. The new date is the 14/15th of August and we are still taking bookings. The event will proceed as usual.
It should also be noted that we have opened the workshop with a number of nissans already been worked on. I would encourage anyone out there looking to get some work done to either give us a call or pop down for a friendly chat.
Cheers,
Trent
The workshop is open but we have moved our "official opening" that was meant to be this weekend to the 14/15th of August.
We will still be using the dyno sparingly and we have a number of cars booked in for the normal workshop side of things. We will be at the workshop on the weekend, so if anyone wants to pop down, say g'day and have a tour of the place, by all means drop in. I would love to meet as many people as possible.
Cheers,
Trent
MERCURY MOTORSPORT
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
