  • Car : Skyline R32 GTS-4 4-Door
So an exhaust leak has appeared in my rb20det, to be honest unsure whether it's the exhaust manifold gasket (half are studs and half are bolts :?) or turbo outlet gasket (only sporting 3 out of the 6 bolts and studs.
So im planning to replace all the gasket around the turbo and exhaust mani at the same time.
So I'm swinging between either buying a few Cometic gaskets to cover my needs???
or buying a full complete OEM gasket kit (I know I don't need them all but its just as cheap)???
This car has been getting built for a few years now, so I do plan to get some power into her.
I already have a cometic triple layer steel head gasket and arp head bolts.
Basically my question is, if I plan to run say about 18-20+ pound of boost in the near future, which gaskets would hold the boost more efficiently and more safely? 'Cometic or OEM'??
I have done a Google Search and what not, but didn't really get the info I needed. :P
Thanks people :D
https://www.sau.com.au/forums/topic/461060-rb20det-gaskets-oem-vs-cometic/
Either are fine really, Genuine OEM is my preference, but people have their opinions on both, generally cost based arguments..
More importantly than gasket choice would be replacing all of the bolts and nuts with proper studs nuts and locking tabs.
just go to bursons and get a standard exhaust manifold gasket and t3 turbo gasket. they normally sell permaseal ones which are good quality.
but since you are missing bolts id be checking how flat the manifold is now, it may need a machine or you will keep blowing gaskets
Hmmm I see, so regarding high boost they are both on the same standard roughly? I just don't want to get an OEM gasket then have it start leaking again when I ramp up the boost.
That's definitely planned, every stud, bolt and nut will be getting replaced for the exhaust side :)
Not too keen on the permaseal, from what I've read their quality is not as good as OEM.
Yeah I will be getting a set of OEM exhaust mani studs at the same time and the rest of the studs and bolts/nuts anndddd a machining if need be... :P
I run 18psi through my nsisan OEM gaskets with no issues so far, all replaced new with new bolts nuts and torqued to spec
Take from that whatever you want :)
That's awesome to hear, thats how much boost I plan to run down the track, hopefully not too far ahaha.....
How long have you been running that setup?
    • Great to hear you are bringing it out of the shed again. Unless you have specific issues I'd just add the wideband, get a good tune and enjoy it. Certainly no point changing coils etc if they are working. If would add fuel pressure and e85 sensor if you are doing a general update but not if it runs OK and you are just getting it back on track. The other thing is smaller, modern twins, -5 are OK for motorsport but pretty laggy and old tech for street use (of course, if performance is the priority a modern single with twin scroll manifold etc is the go but not cheap). The final thing worth considering is switching to an ethrottle if drivability is still an issue, it should make things a lot simpler and smoother
    • Yeah pretty sure they are m4, but best to check, and perhaps use new hardware Also don't over torque them......there was that one time I lost an expensive engine after a workshop overtorqued one of those bolts and it ended up in the oil pump (no, I don't know why they removed the intake mesh either)
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
