mrmotomoto Posted November 18, 2015 Share Posted November 18, 2015 Hello guys I need help identifying what this hose i circled red is called and what does it do, reason i ask is that this morning i drove my GTT on the highway and i instantly noticed a lost in power, my boost gauge shows my max boost today was only 4 PSI as before i ran 10 PSI all the time, i presume this hose is the culprit as it is teared a little bit a while ago to which i wrapped it around in that yellow sticky tape and clamped it together. Link to comment https://www.sau.com.au/forums/topic/461133-help-identifying-this-specific-hose-rb25det/ Share on other sites More sharing options...
Ben C34 Posted November 18, 2015 Share Posted November 18, 2015 Blow off valve return. Being bodgily fixed like that isn't your issue though, that hose sees no boost. Link to comment https://www.sau.com.au/forums/topic/461133-help-identifying-this-specific-hose-rb25det/#findComment-7640193 Share on other sites More sharing options...
KiwiRS4T Posted November 18, 2015 Share Posted November 18, 2015 Save yourself a lot of time and make up a pressure tester. Leaks can be hard to find. Link to comment https://www.sau.com.au/forums/topic/461133-help-identifying-this-specific-hose-rb25det/#findComment-7640194 Share on other sites More sharing options...
mrmotomoto Posted November 18, 2015 Author Share Posted November 18, 2015 Okays thanks for the input guys, i appreciate it Link to comment https://www.sau.com.au/forums/topic/461133-help-identifying-this-specific-hose-rb25det/#findComment-7640195 Share on other sites More sharing options...
mrmotomoto Posted November 18, 2015 Author Share Posted November 18, 2015 hehe, i fixed the issue of losing PSI, i just reset my ECU by disconnecting the battery and now running at 10 PSI again.... What gives? Link to comment https://www.sau.com.au/forums/topic/461133-help-identifying-this-specific-hose-rb25det/#findComment-7640219 Share on other sites More sharing options...
89CAL Posted November 18, 2015 Share Posted November 18, 2015 My car did funny stuff after fitting then removing an atmo bov (back when it was stock and i was cool) and i messed around with everything. Reset the ECU then it was back to normal Link to comment https://www.sau.com.au/forums/topic/461133-help-identifying-this-specific-hose-rb25det/#findComment-7640343 Share on other sites More sharing options...
