Hi all, what would it take to create a car for sound-off competitions?
I mean those crazy things that you see at car shows with heaps of speakers and subs and the like.
I've wanted to make one for a while, but other than the sounds gear, what else is needed?
I'm a little bit (Although not completely) clueless in this area, so any help would be useful.
Cheers
https://www.sau.com.au/forums/topic/461139-building-a-sound-off-car/
buy the right car first (panelvan, wagon, van, etc) then turn it into a giant sub enclosure. remove flex from all panels, seal everything up, with a shitload of expanding foam, sound deadener, bog and plywood...
then, fill it with the biggest subs possible, a crapload of high power amps with the right amount of power for the subs, good dozen of deep cycle batteries to provide the current, and don't forget all the zero gauge cabling
electrical is pretty much the same as any other audio setup, just at a bigger scale. you would at least need several batteries wired in parallel, some fat 0 gauge cabling between the batteries and the amps, upgraded alternator, properly rated fuses, a set of amps capable of driving all the speakers and subs you plan to install and maybe some capacitors as well.
i haven't done a setup like that myself, my most complex build was just a standard head unit/splits/pair of coax/two amps and a sub so wouldn't call myself an expert
Edited by junkie
Fair enough, what do you think the ballpark would be for all gear, excluding the car. Like 3-5k?
3-5k will build a decent oem replacement system with some good quality gear
but sound off, that's a whole different story. amps and subs cost a lot when pushing those kinds of power and decibel levels. plus, you would be up against some cars that have had six figures spent on the installs, so its a case of go hard or go home
I was only really thinking of it as a way to spend some time messing around, as an excuse to enter into shows and such. Not a completely nuts thing. Time to reconsider I think....
a wagon and not a coupe..
then a bunch of subs, slot ported individually and tuned using a SPL meter to see what resonate frequency the sub will peak at... each cabin is different.
I used to be into this shit 1.5 decades ago.
Fire it backwards to load it up (know as superpositioning) which will give you about a 3dB gain - approximately double the "loudness" and with careful port tuning you could pull another 2~3dB from the cabin gain.
I did 146dB with a single 12" Solobaric being fed 1.5kW back in the days however I had a 140L or so box.
I reckon a single 12" DD Subwoofer with about 1kW going to it will push you past 145dB easily in a ported box and if you feed it more it will make even more power.. downside is these subs don't go low and need huge boxes.
http://www.ddaudio.com/products/mobile-audio/woofers/dd9500
Question is, what is your goal and what is your budget?
You can go loud on a budget but you'll need at least a decent subwoofer/driver... get a pair of Jaycar monoblocks and strap them together
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
