Hi Folks,
Project:
Manual conversion of S14 (that got out of hand)
SPEC
Motor: Stock RB25 NEO
Injectors: TBC 100cc
Pump: walbro 450
Turbo: Gtx3076R
Exhaust: 3" with unknown sports cat
Manifold: 6Boost Top Mount T3 Divided single gate
Power Goal:
Ideally 288kw to 300kw not fussy as I want to drive the car
Garret have a shortage of .86/AR exhaust housings which is what iv seen used on the build threads here and in the dyno section.
I ideally want a derivable daily car and I get it the turbo might be a bit big and prob should have looked at a gtx3071 on a stock bottom end NEO.
So here is the question. Will I get away with a divided .78Ar housing at 288- 300kw mark?
Should I order it and shut up?
Should I stick an open .63 on it and have a very expensive open manifold while i wait for a .86?
I Searched:
http://www.sau.com.au/forums/index.php?app=core&module=search&do=search&fromMainBar=1
Projects
AngryRB
http://www.sau.com.au/forums/topic/426934-angryrbs-r33-street-sweeper/?view=findpost&p=6906326&hl=%2Bgtx3076-- Went with another turbo in the end
DiscoPotatos Gt3076
http://www.sau.com.au/forums/topic/440226-gt3076r-antics-better-late-than-never/?view=findpost&p=7223471&hl=%2Bgtx3076
Sort of relevant:
http://www.240sxforums.com/forums/rb-tech/105515-550rwhp-rb25det-my-build-88.html
http://www.sau.com.au/forums/index.php?app=core&module=search&do=user_activity&mid=24715
You are probably looking at a Garrett vs ATP housing. There may be a difference in the quality of the casting. What is the difference in price?
To have any hope of the hotside keeping up flow wise with the GTX compressor, you'd probably want the bigger turbine A/R. I'd suggest the 0.78 might choke a little early. RB engines respond well to a decent flow capacity through the turbine.
Also, if you have reasonable access to E85, get onto that.
I ordered the .78 if it chokes it chokes and Ill get a bigger housing if i need to.
its 850$ vs 300$
So when the .86 genuine Garrett comes back in stock it should be more reasonable.
I'm starting to feel like.
Edited by PatMol
Even the .82 divided chokes the top end, I think a 1.06 would be better personally. If you want better response you should select a smaller turbo not choke a larger one imo. I have seen a GTX3076 run 400kw on e85 in Gregs auto 34 GTT recently, before his head lifted.
Here is a 0.82 split pulse twin gate 6boost setup I did a while back. The results are in the RB25 dyno thread under Owenliberts, I think he posted a few running 98 and e85.
http://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page-43
  • Like 1
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
