Hey all - needing your help in identifying a ticking sound coming from under the car.
No rocks/screws/sticks are caught in any part of the car. The ticking starts at around 70klms, with the noise being more noticeable driving on the highway next to the side rail of if a car/ truck goes past.
I thought it could have been the brake pads - so I changed them (had them sitting in the garage so was a good excuse to change them over to cancel out that)
I've zip tied the front under body plastic guard up in a few places thinking that was flapping about, it's definaetly a speed thing I believe because the noise isn't there when revving the car past a certain rpm.
I thought it was possibly the electrical conduit that runs alongside the chassis rail under the drives side but I've zip tied the cables up to try and stop them from flapping about.
For the life of me I can't figure out what or where the hell it is coming from, any suggestions appreciated.
To my knowledge it's not wheel bearing related as its not a humming/whiring noise. A definite tick tick tick sound.
Cheers for any input!
Did you put a cable tie on your tail shaft? :P
I thought that's just what the cool kids did! - however I was reading somewhere that they had the hand brake cable hitting the drive shaft., not 100% certain of if that's possible
Perhaps check exhaust system from front pipe to tail pipe (studs and gaskets)
Cheers mate will look into that possibility
I have a small rattle/ticking noise also. Mine sounds like a loose heat shield kinda deal but only happens when I'm going 70-90kmh and VERY lightly touching the gas pedal.
Almost like it's in the gear box. Sound comes from center of the car
Edited by B-Turbo
I would def check all the underbody plastics etc as I had a similar issue with part of my front chin flapping about when driving over 60kph. It may look in place now but becomes displaced when driving so give everything a little nudge to check [emoji4]
  • 3 weeks later...
So after tying up a bit more underbody guards and various other items while still creating the ticking sound - browsing a few other car forums and came across one suggesting the wheels weights being loose
So I found the passenger front wheel inside wheels weight was slightly loose (clip on type - not the stick on) - potentially needing over 60/70 kms to vibrate enough to cause the ticking sound..
Ripped that one off and took it for a drive down the highway and no noise. The noise even had my mechanic stumped.
So after weeks of frustration it turned out to be a simple f**king wheel weight....
  • Like 2
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
