Hi all,
I have for sale the following used items from my R33 GTR:
Kakimoto.R Stainless Cat-back Exhaust System with Metal Cat $450
Apexi GT Spec Front Pipe $250
Apexi Power Intake Kit $200
OEM Sway Bars $100
Cat, front pipe and pod filters were on the car for less than 8000 km.
All items in good condition.
Local buyers only please. I am located in Madeley WA. Mobile: 0439657815
Hey mate, are you able to have a look in the mid muffler and tell me how restrictive it looks?
Also if it tapers down to smaller than 80mm in any places like the flanges?
Same with the front pipe, is it 70-80 at the inlets and outlets?
Hi mate,
Took the below measurements.
Main muffler portion inlet: at least 85mm
Mid muffler portion inlet: have not measured as cat still attached
Mid muffler portion outlet: at least 85mm
Front pipe inlets: at least 70mm
Front pipe outlets: at least 75mm
Diameters may actually be larger depending from were you measure from, but I measured purely the open area so might be a bit conservative. Hope that helps.
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
    • I’ll have more of a look into Recaros over the weekend. It’s taken me 2 days to figure out which Bride seats suit my application haha.
    • I am aware of their presence, but the product page looked like that conversion will eliminate the AWD capability. Fact remains it's kind of a hassle to send my oil sump halfway around the world and buying an extra one is expensive and unnecessary. Before I go hat route I'd explore more local options.    Would you recommend I just pull the engine and renew as many things as possible since I'm already having problems with some leaks? Would have to get an engine crane first though.
    • Are there any indicators that the vehicle is in limp mode?  Any dash light, or something.  Or is it just lack of acceleration?
