Looking to upgrade my Brakes. K-Sport Front, and stock rear.
My K-sports haven't had a hiccup yet, but they are not balanced well with my rear. I've been doing alot more track days, and between my tires getting loose, and the sketchy rear swaying, I've decided to look at upgrades. I am just starting to get into understanding brake balancing, and design, so please forgive my ignorance.
First choice would be to get a decent set of rear brakes (AP or Brembo), and upgrade the fronts at a later date.
Option 2 would be to go to the AP full front and rear.
Option 3 is Brembo GT front and rear
Option 4 is R35
In regards to the AP kits, the larger diameter rotor option is cheaper, and the smaller, but thicker rotor is more expensive. Is this the same kit, just the thicker rotor is more expensive? My obvious reaction would be that the larger diameter has more braking power.
The brembo kits have the same size rotors, but the prices are different. I cant seem to find out why.
In regards to the R35, how would the above compare?
And other than the price of the brackets, why hasn't it become more popular on R32-33-34?
thanks!
https://www.sau.com.au/forums/topic/461195-brake-kit-options-r33-brembo-ap-r35/
K Sports (D2 in my case) are fine for the track. Just get something better than stock for the rears. What kind of car have you got and what brakes are on the rear? How many KW do you have or plan to have in the near future?
A thicker rotor can absorb a larger volume of heat, where as a thinner rotor will heat up quicker.
Its the mass of the rotor that gives it the ability to absorb heat, obviously this is dissipated on the straights via air cooling.
Yep diameter adds leverage, in much the same way as it can effect brake balance.
Personally, id be studying a known working setup carefully to save yourself the expensive headaches.
Dont forget caliper piston surface areas and master sizes all play a part in how it works......its not a simple task getting it right.
Dont worry about KW output, worry about the weight of the vehicle, stock heavy cars are far more demanding on brakes than lightened race cars on track, speed for speed.
  • Like 1
Don't forget E=mc2
or in the case of our cars weight and speed matter so KW is relevant .
My Stagea weighs nearly 1800kg and stopping it lap after lap from 250km/hr was not possible with GTT brakes although they were fine on the road. With D2 front brakes (330mm) and GTR rears with Pagid pads problem solved. I am sure they would be adequate for most Skylines unless exceptionally fast.
Bob, I have a GTR33, Single Precision 6466, 544kw to the wheels on E85. So stopping on the street is just as important as stopping on the track. The rears are the stock brembos.
Thanks Peter,
I've been searching threads, and most of them have been hijacked or whored out, making it tough to sort out the useful information. My car is full interior, no roll cage, no CF parts to lighten it up.
R35 Brakes are on the Z-Tune Clubman, and seems to work well, but is the second most expensive option (Brembo GT-R series are $$$$).
Edited by sixmassive
What about the alcon kits a load of guys were getting from jdl in the UK a while back, was a decent thread on them here. Sounded like a good option so might be worth a search.
Sent Alcon a message a bit ago. For Another 200 bucks and i could have a Brembo kit, or save 200 and have an AP kit.
Also send wilwood a message.
Maybe check out the Alpha Omega Racing brake kits.
I saw a thread about them converting evo calipers, but i skimmed over it. I'll give it a closer read in a sec.
Don't forget E=mc2
Correct but covered my arse with the highlighted part you missed....speed for speed :)
If the speeds at application are identical, vehicle mass is the issue. (and Visa-versa)
  • Like 1
Nothing is directly wrong with them. I feel the balance is off. Trying to brake from 4th to 1st, or on a sweeping turn, the rear gets very light, and sways. When braking into a sweeping turn, it gets very squirly.
The K-sports in the front are 8-pot 356mm i believe.
You could get some 330mm for the rear: http://ksportusa.com/b2c/proddetail.php?prod=BKNS170-433SO
Just get some decent pads.
I have the same issue with mine and I'm guessing it's because I only have Bendix generals in the rear. I'm going to swap to a more aggressive pad when they're due and see if that helps.
First things first. What shocks and spring rates are you running? What tyres brand and sizes are you running? What wheel alignment are you bashing around the track on? What ride heights front and rear are you running Lastly what pads are you running front and rear?
If you are trying to get a brake setup that ensure the car is settled under big stops then its best to make sure you are looking at the right thing. 7 times out of 10 if you want to shorten braking distances or improve braking stability it will be tyres and suspension.
  • Like 3
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
