Looking to upgrade my Brakes. K-Sport Front, and stock rear.
My K-sports haven't had a hiccup yet, but they are not balanced well with my rear. I've been doing alot more track days, and between my tires getting loose, and the sketchy rear swaying, I've decided to look at upgrades. I am just starting to get into understanding brake balancing, and design, so please forgive my ignorance.
First choice would be to get a decent set of rear brakes (AP or Brembo), and upgrade the fronts at a later date.
Option 2 would be to go to the AP full front and rear.
Option 3 is Brembo GT front and rear
Option 4 is R35
In regards to the AP kits, the larger diameter rotor option is cheaper, and the smaller, but thicker rotor is more expensive. Is this the same kit, just the thicker rotor is more expensive? My obvious reaction would be that the larger diameter has more braking power.
The brembo kits have the same size rotors, but the prices are different. I cant seem to find out why.
In regards to the R35, how would the above compare?
And other than the price of the brackets, why hasn't it become more popular on R32-33-34?
thanks!
https://www.sau.com.au/forums/topic/461195-brake-kit-options-r33-brembo-ap-r35/
K Sports (D2 in my case) are fine for the track. Just get something better than stock for the rears. What kind of car have you got and what brakes are on the rear? How many KW do you have or plan to have in the near future?
A thicker rotor can absorb a larger volume of heat, where as a thinner rotor will heat up quicker.
Its the mass of the rotor that gives it the ability to absorb heat, obviously this is dissipated on the straights via air cooling.
Yep diameter adds leverage, in much the same way as it can effect brake balance.
Personally, id be studying a known working setup carefully to save yourself the expensive headaches.
Dont forget caliper piston surface areas and master sizes all play a part in how it works......its not a simple task getting it right.
Dont worry about KW output, worry about the weight of the vehicle, stock heavy cars are far more demanding on brakes than lightened race cars on track, speed for speed.
  • Like 1
Don't forget E=mc2
or in the case of our cars weight and speed matter so KW is relevant .
My Stagea weighs nearly 1800kg and stopping it lap after lap from 250km/hr was not possible with GTT brakes although they were fine on the road. With D2 front brakes (330mm) and GTR rears with Pagid pads problem solved. I am sure they would be adequate for most Skylines unless exceptionally fast.
Bob, I have a GTR33, Single Precision 6466, 544kw to the wheels on E85. So stopping on the street is just as important as stopping on the track. The rears are the stock brembos.
Thanks Peter,
I've been searching threads, and most of them have been hijacked or whored out, making it tough to sort out the useful information. My car is full interior, no roll cage, no CF parts to lighten it up.
R35 Brakes are on the Z-Tune Clubman, and seems to work well, but is the second most expensive option (Brembo GT-R series are $$$$).
Edited by sixmassive
What about the alcon kits a load of guys were getting from jdl in the UK a while back, was a decent thread on them here. Sounded like a good option so might be worth a search.
Sent Alcon a message a bit ago. For Another 200 bucks and i could have a Brembo kit, or save 200 and have an AP kit.
Also send wilwood a message.
Maybe check out the Alpha Omega Racing brake kits.
I saw a thread about them converting evo calipers, but i skimmed over it. I'll give it a closer read in a sec.
Don't forget E=mc2
Correct but covered my arse with the highlighted part you missed....speed for speed :)
If the speeds at application are identical, vehicle mass is the issue. (and Visa-versa)
  • Like 1
Nothing is directly wrong with them. I feel the balance is off. Trying to brake from 4th to 1st, or on a sweeping turn, the rear gets very light, and sways. When braking into a sweeping turn, it gets very squirly.
The K-sports in the front are 8-pot 356mm i believe.
You could get some 330mm for the rear: http://ksportusa.com/b2c/proddetail.php?prod=BKNS170-433SO
Just get some decent pads.
I have the same issue with mine and I'm guessing it's because I only have Bendix generals in the rear. I'm going to swap to a more aggressive pad when they're due and see if that helps.
First things first. What shocks and spring rates are you running? What tyres brand and sizes are you running? What wheel alignment are you bashing around the track on? What ride heights front and rear are you running Lastly what pads are you running front and rear?
If you are trying to get a brake setup that ensure the car is settled under big stops then its best to make sure you are looking at the right thing. 7 times out of 10 if you want to shorten braking distances or improve braking stability it will be tyres and suspension.
  • Like 3
    • Alright guys, I've got good odds the motor survives due to a majority of spare parts. Who's taking bets on clutch, who's on transmission, and who's go diff? Happy to also take bets on if it still overheats in traffic or not 😛     Car looks amazing by the way. I've never been a fan of R34 rears, so really, I don't think any body kit etc solves that for myself, but the front end looks amazing!
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
    • Nvm ignore this I read it wrong
