Hey guys
Sold my car and have some parts that never got a chance of using and some OEM used ones, basically a garage clean out will keep adding as i find more stuff.
1) Brand New in unopened box CST Type Vettel V36 coilovers fully adjustable with 14k front and 9k rear spring rates and 16 way damper. These are made in Japan and distributed by Tanabe. $1500 ono (pic of suspension out of box from google, i havent opened my box yet)
2) Blitz Power-sus intake panel filters also BNIB $120
3) V36 Type S and SP front lip kit ( Fibreglass sides with CF middle part, see pics) $550 ONO
4) RS-S LowDown springs BNIB $400
5) OEM Used Exhaust axle back Muffler and y-pipe $100
6) OEM Used Manifold $100 (good for anyone needing to send one into z1motorsports as core unit)
7) OEM Used rear chrome bootlip $50
8) OEM Used 18" V36 Coupe wheels made by enkei in excellent condition need tires $500
9) OEM Used 18" V36 Sedan Type SP wheels also in excellent condition (front tires good, rears need replacing) $500
10) BNIB plug and play V36 cruise control kit (comes with a little wheel knob that can be used to set/cancel and increase/decrease speed see pics) $500 ONO
Thats all from the top of my head, like i said if i find more stuff ill keep adding.
Offers only accepted if i have put an ONO next to the price or else its non-negotiable.
PM will be the best way for enquiries and everything located Southwest of Brisbane
https://www.sau.com.au/forums/topic/461196-v36-parts-for-sale-garage-cleanout/
  • Replies 60
Posted Images
It works both as a cruise and throttle controller, install is simple plug and play as it is V36 specific and will fit into factory accelerator harness and a few wires need to be hard wires like power and brake pedal. Check the attached wiring diagram.
VQ35HR and VQ37VHR Carbonfibre intakes used for about 1000-1500kms only.
$350
Was there a reason you removed it after a short time ? Did you notice any performance increase or atlest better exhaust note while it was in the car ?
Thanks mate
Thanks mate
Removed as i was selling the car and had recently bought them and i wasnt gonna get much back after owning the car 3 yrs so took out a few bits and selling them.
Not sure about performance gains but it has a real good induction sound and exhaust got a tad bit louder too.
  • 1 month later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
