Hey guys
Sold my car and have some parts that never got a chance of using and some OEM used ones, basically a garage clean out will keep adding as i find more stuff.
1) Brand New in unopened box CST Type Vettel V36 coilovers fully adjustable with 14k front and 9k rear spring rates and 16 way damper. These are made in Japan and distributed by Tanabe. $1500 ono (pic of suspension out of box from google, i havent opened my box yet)
2) Blitz Power-sus intake panel filters also BNIB $120
3) V36 Type S and SP front lip kit ( Fibreglass sides with CF middle part, see pics) $550 ONO
4) RS-S LowDown springs BNIB $400
5) OEM Used Exhaust axle back Muffler and y-pipe $100
6) OEM Used Manifold $100 (good for anyone needing to send one into z1motorsports as core unit)
7) OEM Used rear chrome bootlip $50
8) OEM Used 18" V36 Coupe wheels made by enkei in excellent condition need tires $500
9) OEM Used 18" V36 Sedan Type SP wheels also in excellent condition (front tires good, rears need replacing) $500
10) BNIB plug and play V36 cruise control kit (comes with a little wheel knob that can be used to set/cancel and increase/decrease speed see pics) $500 ONO
Thats all from the top of my head, like i said if i find more stuff ill keep adding.
Offers only accepted if i have put an ONO next to the price or else its non-negotiable.
PM will be the best way for enquiries and everything located Southwest of Brisbane
https://www.sau.com.au/forums/topic/461196-v36-parts-for-sale-garage-cleanout/
  • Replies 60
Posted Images
It works both as a cruise and throttle controller, install is simple plug and play as it is V36 specific and will fit into factory accelerator harness and a few wires need to be hard wires like power and brake pedal. Check the attached wiring diagram.
VQ35HR and VQ37VHR Carbonfibre intakes used for about 1000-1500kms only.
$350
Was there a reason you removed it after a short time ? Did you notice any performance increase or atlest better exhaust note while it was in the car ?
Thanks mate
Thanks mate
Removed as i was selling the car and had recently bought them and i wasnt gonna get much back after owning the car 3 yrs so took out a few bits and selling them.
Not sure about performance gains but it has a real good induction sound and exhaust got a tad bit louder too.
  • 1 month later...
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that green thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
