Hi all.
Recently acquired an 89 R32 GTS coupe ( RB20DE, auto ) and decided to sign up to the forum after finding a wealth of good info that has helped me with the few issues I've had to resolve.
I purchased the car mid october and while mechanically sound and reliable, the burgandy paintwork was atrocious and needed to be addressed.
I spent a week preparing the car for a respray and awaiting the ideal weather conditons to apply the paint.
Once content with my preparation ( far from perfect ) and with a warm dry day I tarped up the carport and laid on a black acrylic base-coat, followed by several clear-coats infused with a violet-metallic flake powder, at 5 grams per litre of thinner-diluted clear.
The results aren't immaculate, but I'm pretty happy with them. I still have plenty of polishing to do, and re-coated the bonnet earlier today as I just couldn't get it right the first time.
R32 GTS
The car is pretty much standard except for a pod filter ( exposed ) some interior trim, sports wheel & pedals, and the stereo.
I bought it with 224,000km on the clock but it runs fine and feels strong.
The only two issues I've encountered so far were replacing the passenger seatbelt ( from an S13 ) as the original jammed repeatedly, and replacing the power-window assembly in the drivers door.
Looking forward to contributing to the community.
  • Like 1
https://www.sau.com.au/forums/topic/461255-hi/
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
