Hi all
Long time no boost.
Time to feel the rush again. this time not just a stock rb25det with intercooler.
I have an apparent F6 Turbo im puttin on my forged RB30 today, i think its BB but not 100% sure & i want your advise.
Features:
6 bolts either side
spins around 13 seconds after blasted with air gun
looks like restrictor in top oil feed but its 3-4mm
pics attached
BTW what do you think of a 5" dump pipe i made for this performance wise ?
Cheers
Ball bearing turbo's don't need a lot of oil flow, and the GT35 likes to burn a little oil if the feed is opened up from my experience. I would start with a 1mm restricted AN fitting for the feed and see how it goes.
A filter in the feed line is a good idea, not a little pissy one, a larger stainless mesh filter to take out any crap that may block the 1mm hole.
Pretty sure the F6 still ran a 3 inch inlet, so this would be an aftermarket GT35, do you have some pics of the dump flange side?
Yep, Falcon GT35 didn't have a large inlet but they did have that smaller A/R. Maybe it changed at some point?
Unless you change the front A/R and aiming for 380rwkw, bit of a poor turbo choice IMO.
Better off with a GT30 with a 1.06 AR if 300rwkw-330rwkw is the goal, even a .82 works well, comes on early and hard though so you need a decent investment in tyres/diff/suspension
  • Like 1
Cheers guys i called up honeywell & gcg, they said max oil pressure of 45 psi to the turbo for this one, it has a restrictor built in around the corner from oil feed but still needs 1mm restrictor pre turbo so i bought one thursday arvo.
Yeah i was thinking of getting an inline oil filter as enzed didnt stock any when i got the restrictor. so i will order one online thanks.
This turbo came on a spag manifold with a plated vl turbo with lots of mods, forged, int, fullspool, 31 spline billet axles etc etc. and LOTS of spares all for 2.5k.
i just had to make it work IE make dump/ lines/ spacer etc it gets rego this week.
This turbo is better then no turbo so i slapped it on i know its a fair upgrade from a stock rb30 turbo that pumps a pissant 150 kw, this one pumps 310kw so im expecting laggg etc. I dont know heaps about them but ill test it. then change it if i dont like it, next is comp & tune.
what turbo would you suggest for rb30 300 kw give or take ?
what sort of power can these boost to safely 400kw ? more i guess
Turbo exit pic attached
With the current turbocharger you have. Run it with a .82 rear housing, should see pretty responsive 360rwkws mark. The next size up would be a GTX3582, or just fit a GTX3582 wheel to your current CHRA.
GT30 as I said above for 300-330.
You can get 400rwkw on E85 with the current turbo you have. The XR6 GT35s always seem to be a tad shorter on the power, probably the compressor A/R at the upper end making a slight difference. Overall compressor A/R doesn't make that much difference, turbine far more important.
If you are going E85, get a GTX series. If you are staying on PULP then the GT series are the better choice IMO. GTXs only really shine at the higher boost ranges (talking 20psi++)
Really depends what the use will be, it's too large for the street if you want response, but as a track turbo it would work well imo.
I much prefer a smaller turbo and leaning on it harder (for the street) but a 3L should spool the GT35 up nicely anyway.
    • Hi again all, I’ve tried doing some searching on the topic but couldn’t find the answer I’m looking for.   I deleted my clutch booster because it had an air leak and was squealing like a hog, and now my clutch has very poor pedal feel and the friction zone is way too small, so I believe I need a bigger diameter clutch master cylinder to compensate for not using the booster. I found a Wilwood option that’s 3/4” for a good price and will fit my 3AN clutch line, but all the firewall adapters I see online such as RB factory or Chase Bays are listed as RWD only (GTST/GTS). Link below. https://rbfactory.shop/products/nissan-to-wilwood-girling-clutch-master-cylinder-adapter My question is if these adapters will also fit a GTR, and if anyone has experience using a 3/4” CMC without the booster, my clutch is a Nismo coppermix twin plate.   Thanks, always appreciate the advice!
    • Catching up on a post, I've replaced the external shark fin with a small 4g antenna (no further drilling, just a 1mm embiggening of the existing hole, and run that to where the dual battery models have the battery in the left rear guard.  No idea what the factory antenna did, but removing it had no impact on anything I use, according to the US manual the GPS antenna is in the dash and it still works fine Also ended up stealing battery power from one of the amps and ACC power from a unit nearby to add an ACC relay to power it. The mounted the booster, wifi, power socket and antenna splitter in the rear left guard out of the way, all out of site with the boot trims in
    • What drama? The only drama you're going to have is the near constant work to maintain all those sphericals. I only have sphericals in my front caster rods and front upper CAs (because both of these are near compulsory in an R32). I have had the front arms out of my car 34 times already this month, and if the new replacements arrive today, I will have them out and apart again tomorrow. Chasing clicking and clunking that comes from sphericals being a.....poor choice for a road car. Moisture and dirt are not their friends. I have been contemplating a change to my rear subframe that would require me to use sphericals in my lower CAs. And.....I don't want to have them that close to the road.
    • Did you need anything else you've already done? If you had it before... and liked the changes after, then supposedly it'd be more of the same. The idea about most suspension arms is to tune geometry that the OEM arms max out at/can't handle because they weren't designed to have the car setup in such a way that 'looks good'.
    • I have replaced everything on my r34 including suspension to Miester R, all rear subframe bushes to poly, all arms to metal adjustable and same in front.   only thing I haven't touched is the front lower control arm. Should I? what improvement can i expect ? I mean the one on the link below?   Car drives perfectly, it is just me thinking everything is either puly bush or hard bearing type so should also do lower control arm front but do I really need it ? https://www.japspeed.co.uk/product/suspension/adjustable-arms/nissan-200sx-s13-s14-s15-skyline-r32-r33-r34-adjustable-suspension-front-lower-control-arms/?gad_source=1&gclid=Cj0KCQiAo5u6BhDJARIsAAVoDWs5V_PauQPf0kx3zFCaA4tOC9Q7JSIsfJWma_jAPN2f1sJA686djOwaAidgEALw_wcB
