I don't know much about the different brands of EBC's out there but am looking to buy a new one. I have a tial 38mm with a 15.9lb spring with my he341 holset and RB20det. The wastgate can be heard opening at around 10lbs and and creeps to 15lbs high in the rev-range.
I would like to find an EBC that I can adjust gain and get the 15psi earlier and faster.
From my understanding a good EBC will improve mid-range boost levels and subsequently HP/Tq
I know they have gotten to the point where they will need certain wires spliced form the ecu. I am not looking to spend over 350$ but I would like to know what you guys think works good with the RB's.
What kind of ecu do you have? Your best bet is to get a Mac valve controlled by the ecu if it is capable.
Like this:
http://www.trademe.co.nz/Browse/Listing.aspx?id=985722031
KiwiRST4 - I am running Nistune, ECU was too old to add the feature pack apparently.
GTSBoy - That's what I figured, wasn't sure if there was one that was more compatible with the RB wiring.
Having said that what's the best bang for your buck module?
innovate have the afr/boost controller combo that you can connect with nistune.
You want something at least dual solenoid.
Blitz EBC, HKS, Greddy etc.
Apexi is not dual, don't waste money on them as for the price the other above are far better value (and will work better)
  • Like 1
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
