What about NISMO injectors? They're junk Sard garden hoses with a Nismo sticker.
Their suspension arms. Cost a bomb (or as much as Ikeya stuff) yet you don't have anywhere near the adjustment. Painted silver but!!
The list could go on forever.
They do make some decent gear like the rear diffs, clutches and are actually reasonably priced. Most of it is just "warmed up" and hardly worth the money.
But you have a NISMO clutch in your car?
Just like most of us did/do...
At least they got one thing right
Last paragraph mate.
Not saying it's all junk. The diffs and clutches are fantastic. Absolutely no question there. That clutch is THE clutch to have one a street GTR.
  • Like 1
Lots of Nismo hate... And I've bought two Nismo items in the past 4 days [emoji15]
One of those items was a fuel pump... I can't bag the price of Nismo too much - the identical Tomei fuel pump was double the money of the Nismo!
  • Like 1
I installed a Nismo thermostat in my R33. Was great, car never got the chance to get out of cold tune! And it only cost $120!
So glad I didn't spend $40 on an OEM thermostat that would hold a collant temp over 60 deg C, fuel economy is for chumps!
/Sarcasm
  • Like 1
Walbro would be half the cost and flow even more and be e85 compatible.
Won't be a direct fit i suppose though
a hose clamp and 2x wire crimps aren't exactly brain surgery lol
  • Like 1
Maybe not, but I've read mixed reviews on Walbro pumps, where as I've heard no negative comments about the Nismo pumps. It also includes everything for a painless swap, including the large o'ring that seals the fuel pump opening. The flow of the Nismo pump is a good match for the rest of my gear (injectors, turbo etc) so the higher flow rate of the Walbro would be a waste.
Hard pipes usually do the exact opposite - in that - they make shuffle far more pronounced/problematic. Particularly when running larger twins, stock turbos not a problem but upgrade to -5s or 2530s and you're in for a tuning headache.
So no, they are certainly not a good upgrade IMO. Plenty on this forum have even REMOVED the hard piped and gone back to stock ones for that very reason, plenty of posts about it. So definitely something that article fails to touch upon but then he's still running stock turbos... They should be the first thing you change, not everything else first.
Just curious, why do the group A R32 Gtr such as the Calsonic and Gibson motorsports have the hard pipes then? I thought the hard pipes gave less flex compared to stock rubber and had better merger Y pipe before going into intercooler?
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
