Just curious, why do the group A R32 Gtr such as the Calsonic and Gibson motorsports have the hard pipes then? I thought the hard pipes gave less flex compared to stock rubber and had better merger Y pipe before going into intercooler?
Do the twin turbo pipe mod for $100. Put the other $1800 elsewhere... Like a front diff.
If it's good enough for 470 kW on -5's it's good enough for you.
The value for money here is NOT worth it, especially early on.
  • Like 1
Waiting for you to sell me your modded twin turbo pipe LOL.
Race cars are ALWAYS bad examples of what to do on a street car when driveability comes into question
  • 3 months later...
OK, so recently installed the Nismo inlet pipes on my car and thought I'll post some thoughts. First of all, it's very shiny, does give the engine bay more bling. It sounds slightly louder with air rushing in, could also be the air box without the snorkel as my attempt to melt the stock snorkel to fit back failed miserably.
Now I've only given it a bit of drive so these are only initial bum of the pants fell. Couldn't tell much difference under 4000 rpm, but from 4.5-5k and higher it does seem to go a bit harder, maybe a tiny increase in power but not a massive difference. Checked the ebc and boost seems to go a bit higher. My ebc is set to 19psi and can overboost some time to 20-21psi. After the Nismo pipes the peak shows 22.3psi, so I think boost has gone up maybe 1psi after install. Didn't notice any turbo shuffle on my -5s and my car is mildly tuned to around 310-320rkw.
Now before people flame me, like I said these are only initial thoughts, I will be going to dyno the car soon so hopefully will be able to see if there are any actual differences at all ( will be on same dyno ). Is it better than the modifed twin turbo pipe? I don't know, could've net the same gain if any, it certainly looks better thank stock pipe.
So in conclusion no real negatives (on my setup anyway) besides a burning hole in my wallet. If anyone is interested I might do a write-up with photos.
Would love to see a back to back...
Probably extra 5kW gain, works out about 1kW = $400 lol
Yeah back to back be good, make sure the ambient temp is roughly the same both days and tyres are inflated properly.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
