Noticed yesterday that my tail lights don't work anymore.
If I brake, it works fine but having the lights on, just the headlights will work.
Thought I may have blown a fuse while installing the new head unit.
Checked the fuses next to the accelerator pedal and they are all good.
Is the fuse for lights in another fuse box?
Has anyone had this problem before ? Couldn't find anything here or on m35stagea forum.
https://www.sau.com.au/forums/topic/461325-tail-parking-lights-not-working/
Just checked all fuses there and they are all good.
Checked the side tail lights and lamps are not blown either. Not sure which taillights are on actually when you turn them on but I think it is the same as the brake light.
What's weird is that my brake lights work fine.
Gonna check the tail light block with my multimeter to see if I get current there at least which I doubt
Edit: Checked, no juice and blew the brake light fuse to be able to locate it. It's near that accelerator pedal.
Edit2 : found this on the forum and can't see the lights fuses in this so there is still hope :)
Edited by valf
As I was looking for the bung under the battery, I removed more pieces of the car and found the 3rd fuse box just above the drain bung and the blown fuse too ! :)
So the story is that my new head unit I installed was blowing my tail lights fuse. The harness I got is probably not the good one (even though the HU works perfectly)
After blowing a couple more fuses, I unplugged the heat unit ... (removing the fascia for the 3rd time .. sigh) and fuse didn't blow up anymore.
Here is a picture of the fuse cover in the top right of the engine bay
Seen from an other topic after a long search
DONT NOT GROUND THE RED/BLUE WIRE!!!! it is actually the cabin lights/parkers/tail lights!!!
This! Exactly what I did, blew the fuse
Got music now :) Everything is working again
  • 5 years later...
http://i.imgur.com/cvXcgUT.jpg
Churr bro need help as my Nissan stagea is doing the same thing were bouts did u find the fuse box bro
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
