Where's my bunnings gift cards?
I don't own a vw, but I breathe their fumes every day.
I need financial compensation dammit!
On a srs note, how many cars have they checked on a licensed test bed vs street use?
As with all cars imported into Australia, all emissions are presumed to be that of the original test car.
Maybe the original car did pass.
The subsiquent cars didn't.
Also, was the test vehicle new?
Run in?
Correct oil?
Correct fuel?
All can be argued makes a difference.
And vw allow 500ml of oil use every 1000kms (stated in the owners handbook).
This could also add to emissions.
  • Like 1
Is that for real? So after 10,000km, VW reckons 5L of oil usage is okay?
yes.
Is actually in the handbook.
And the services are every 15k.
So, 7.5L of oil.
Most only take around the 5L mark.
Ours is the 103TDI so not included in this little upsettedness.
It uses a fair bit of oil, we have to top it up every month or so. We do a few k's in it but it kinda makes me uncomfortable.
Are there very many VW owners out there who wouldn't buy a VW again; and for reasons other than this recall issue?
I guess I'd need to check reviews comparisons after medium term usage.
I'm not interested in new car reviews, as they only tell half the story.
Terry, my wife and I love our Passat. Its a fantastic car that does domestic and road trip duties very well. Its put up with our family and the dogs and is just effortless in its work.
BUT, I feel that I can't trust VW now. My issue is with the manufacturer, not the car.
  • Like 1
I was looking into an mk5 GT sport diesel earlier this year... after digging deep into the direct injector issue that was basically affecting every car with that particular motor, VW never issued a recall and would only replace on warranty if the owner took the car to the dealership (after it had broken down).
no one on the internet ever confirmed it if was injector or loom related.
That plus early DSG issue... its not that these issues arent now resolved, its VW's lack of action towards addressing the issue and doing everything in its power to not do a recall.
All our injectors and loom were replaced. We got a letter from VW about it. Not sure if it was an 'official' recall or just a 'make good'.
I'd buy a VW again.
I have 103 tdi. Uses no oil 108xxxkm.
Ours only started recently. 160k. Hopefully mech at next service can fix that. Def no oil under the car (whew).
  • 4 months later...
MITSUBISHI last week
DAIMLER BENZ this week
PEUGEOT probably too
...pinged for emissions aberrations and probable fudging.
  • Like 1
  • 8 months later...
F.B.I. Arrests Volkswagen Executive on Conspiracy Charge in Emissions Scandal
http://www.nytimes.com/2017/01/09/business/volkswagen-diesel-emissions-investigation-settlement.html
"The arrest came as Volkswagen and the Justice Department neared a deal to pay more than $2 billion to resolve the criminal investigation into the emissions cheating. The company or one of its corporate entities is expected to plead guilty as part of the deal."
"Volkswagen has already agreed to pay up to nearly $16 billion to resolve civil claims in what has become one of the largest consumer class-action settlements ever in the United States, involving half a million cars."
  • Like 1
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
