Where's my bunnings gift cards?
I don't own a vw, but I breathe their fumes every day.
I need financial compensation dammit!
On a srs note, how many cars have they checked on a licensed test bed vs street use?
As with all cars imported into Australia, all emissions are presumed to be that of the original test car.
Maybe the original car did pass.
The subsiquent cars didn't.
Also, was the test vehicle new?
Run in?
Correct oil?
Correct fuel?
All can be argued makes a difference.
And vw allow 500ml of oil use every 1000kms (stated in the owners handbook).
This could also add to emissions.
  • Like 1
Is that for real? So after 10,000km, VW reckons 5L of oil usage is okay?
yes.
Is actually in the handbook.
And the services are every 15k.
So, 7.5L of oil.
Most only take around the 5L mark.
Ours is the 103TDI so not included in this little upsettedness.
It uses a fair bit of oil, we have to top it up every month or so. We do a few k's in it but it kinda makes me uncomfortable.
Are there very many VW owners out there who wouldn't buy a VW again; and for reasons other than this recall issue?
I guess I'd need to check reviews comparisons after medium term usage.
I'm not interested in new car reviews, as they only tell half the story.
Terry, my wife and I love our Passat. Its a fantastic car that does domestic and road trip duties very well. Its put up with our family and the dogs and is just effortless in its work.
BUT, I feel that I can't trust VW now. My issue is with the manufacturer, not the car.
  • Like 1
I was looking into an mk5 GT sport diesel earlier this year... after digging deep into the direct injector issue that was basically affecting every car with that particular motor, VW never issued a recall and would only replace on warranty if the owner took the car to the dealership (after it had broken down).
no one on the internet ever confirmed it if was injector or loom related.
That plus early DSG issue... its not that these issues arent now resolved, its VW's lack of action towards addressing the issue and doing everything in its power to not do a recall.
All our injectors and loom were replaced. We got a letter from VW about it. Not sure if it was an 'official' recall or just a 'make good'.
I'd buy a VW again.
I have 103 tdi. Uses no oil 108xxxkm.
Ours only started recently. 160k. Hopefully mech at next service can fix that. Def no oil under the car (whew).
  • 4 months later...
MITSUBISHI last week
DAIMLER BENZ this week
PEUGEOT probably too
...pinged for emissions aberrations and probable fudging.
  • Like 1
  • 8 months later...
F.B.I. Arrests Volkswagen Executive on Conspiracy Charge in Emissions Scandal
http://www.nytimes.com/2017/01/09/business/volkswagen-diesel-emissions-investigation-settlement.html
"The arrest came as Volkswagen and the Justice Department neared a deal to pay more than $2 billion to resolve the criminal investigation into the emissions cheating. The company or one of its corporate entities is expected to plead guilty as part of the deal."
"Volkswagen has already agreed to pay up to nearly $16 billion to resolve civil claims in what has become one of the largest consumer class-action settlements ever in the United States, involving half a million cars."
  • Like 1
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
