Hi all , I searched high and low and cannot find the injector dead time voltages I need to get these working with a ViPec R33 plug in ECU .
BTW there is no paper work in the box and no they're not fitted yet . I may have to get a local workshop to do this but I'll no doubt have to do the injector setting myself .
Any help appreciated cheers Adrian .
Easiest way is to keep the same VE table as with your current injectors, then scale your new injectors to the correct size then adjust the dead times till you hit stoich (or whatever afr you idled with your old injectors).
should try what I recommended earlier, however I know you're the type not to listen so here is what you're looking for.
Fuel Pressure Offset Slope (psid) (Āµsec) (cc/min) 8 Volts 10 Volts 12 Volts 14 Volts 16 Volts 40.0 2195 1495 1115 885 710 845 43.5 2280 1540 1145 910 730 885
(noticed the table lost its formatting, you'll work it out)
  • 8 months later...
Ɨ
Ɨ
