Hi Guys,
Mates custom 10 sec lancer with VR4 conversion done was stolen tonight (15/07/04), was left for around half an hour in port macquarie (NSW mid north coast) when it was taken. Car will stand out as is one of if not the only 90 gsr lancer with 4WD running gear. was white with plates UNO.18U and big blue sticker up the side saying "bad influence motorsport". $2000 reward for anyone with info leading to the recovery.
Thanks guys.
This is some pics of the car....
-Jamie
https://www.sau.com.au/forums/topic/46134-stolen-10sec-90-gsr-lancer/
this is a free lesson to everyone else, dont leave your modified cars anywhere but where you can keep and eye on it, or in a locked garage at home, if your gonna go shopping buy a $500 datto 120y.
sorry to hear your about your mates loss, someone tried to rip my gtr in front of my house the other night and the front door was open, lucky i got good neighbours.
mst probably the car is down to bare metal already wit the parts being sld as we speak to other car enthusiats.
good luck finding it.
shit man tough luck hey
i rekens Aus needs some serious rethinking of our car theft laws.
In the middle east theves get there hands chopped off if they are cought, i reken that should solve our theft problem :D as well as a lengthy holiday in the pen, sharing a room with a large, hairy, tottooed man who calls himself 'spider'
hope u get her back
hope u get her back
spider isnt a dangerous or scary name, i think butch or baba would be beter.
hey, im jono's cousin. the car has been recovered. they found it in kempsey last night, not sure exactly how they heard it was there but its back so thats something. its been stripped of a few parts, and they jumped all over the roof and bonnet. its back in the workshop already
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
