Hi,
I'm at a bit of a loss with my R34 GTT. Soon after I got it I'd get a very occasional miss, then the TCS, Slip and Check Engine lights would come on for the rest of the journey. A bit of reading here suggested coil packs.
After a while it got worse. The miss would persist until I restarted the car, sometimes for a minute afterwards. I also became aware then the engine note had changed slightly, somehow rougher, even when it wasn't missing.
I finally bit the bullet and bought some Yellow Jackets and fitted them this weekend. However I now get the TCS and Slip lights as soon as I turn the key, and Check Engine light once it turns over. The odd engine note has persisted too.
Car has done 150,000 Ks, major service done at 94,000 Ks (not by me). Has anyone come across this, or know of an obvious cause?
Thanks.
Thanks for your responses.
I don't think I broke any of the coil harness connectors, but a lot of the plastic in there felt really brittle.
I didn't change the plugs while I had it open. Probably should have while I had the chance.
Guess next weekend's job is opening it up again and doing plugs and harness.
Change the plugs and inspect the coilpack loom for damage, as you mentioned it felt brittle
The loom itself and it's insulation gets heat-cycled a lot and becomes brittle over time which causes wires to earth out or break
Kudos have replacement loom sections for the coilpacks, unplug and replace :)
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
